More torque for my Power trac?
/ More torque for my Power trac? #72
Stray,
Are your wheel motors rated at 1500 psi , or 3000 psi?
JJ. Kent said 2250 PSI, peak, and intermittent at 1750 PSI. I am not sure what the tram pump puts out but they should handle it because as I said with the rear wheels in the air while pushing on a dirt pile the front motors would be receiving the full psi pump pressure.
Bobrip one might need to let off the peddle when switching modes but surly it would switch then.
Thanks snowridge that may be what this system needs to prefect it. It does regulate in both directions doesn't it?
Moss you are rated 3 more HP than mine. I am sure that makes some difference. Question? Say if you have a full load in the bucket (800 lbs of dirt) on dry blacktop what grade would it take to stall your PT. Now if your system is routed like mine the back should not spin unless the front does.
/ More torque for my Power trac? #74
This is MHO, thinking out loud.
In a series circuit the pressure at the pump must be the sum of the pressure drops across the motors.
This circuit is most efficient where the load on each motor is the same, but when one motor is spinning, you lose climbing power, and the only to fix that is to have equal weight on each wheel, which is hard to manipulate. It is not impossible, because something like a weight shifting device would transfer weight to the wheel that is spinning.
If you put them all in parallel, those 1750 psi motors will see up to 3000 psi, on each motor. I am thinking that at some time, you will exceed the hydraulic limitation, and blow the seals or what ever. It appears that they selected those motors for a series arrangement, and then put those circuits in parallel. I believe that all my motors are 3000 psi motors, and can take the full pressure from the VSP pump. If I want more torque, I have to increase pressure, Which is not feasible.
/ More torque for my Power trac? #75
If those wheel motors are the 12.5 cu RS200s, they are rated at 1,500 psi continuous, 1,750 psi intermittent, and 2,250 psi peak.
/ More torque for my Power trac? #76
Therefore, my point. You could put a relief valve if it does not already have one, in the circuit, but, don't know what will happen. If it does relieve anything above 1750 psi, the fluid will heat up fast and further reduce the efficiency.
So, in a test of this circuit, a pressure gage is warranted and a temp gage also.
/ More torque for my Power trac? #77
JJ...
That's a good question. I don't have any place paved or concreted steep enough to try it. I've always made it up the slopes or spun the wheels but never stalled the engine.
/ More torque for my Power trac? #78
Stray,
Here in Florida on my place, it is all flat. As far as stalling, whenever you exceed the weight limit/torque that the machine was designed for, you will do one of two things. 1. If you have a good pump, and good engine, when you come up on the stall point, the relief valves will cut in. 2. If you spin a tire or two tires, then you are asking the other wheel motors to take up the slack. Does anyone know the regular weight on each wheel motor? How about the weight on each tire when you have a full bucket of wet dirt? I am not a mechanical engineer, but there is some calculations needed when you know the static limits, and then to know the conditions that are present on an incline, the weight on each wheel will shift somewhat. Going up a hill with a full bucket, you are adding weight to the front wheels, and reducing the weight on the back wheel. In that situation, I would expect the rear wheels to slip or spin, and even though you have the extra weight on the front wheels, the two wheel motors are not enough to overcome the load on an incline. The spinning wheels is lost energy, and if you could add some weight to the spinning wheel or increase the torque then it might happen.
If your engine stalls out, It means that you have a weak engine, or you are running all the pumps at the same time, or the relief valves are not working as they should.
Ok so far this is what I have found out. The new system works well. The PT will climb places with loads that before I would not even attempted. As we thought one wheel has potential to spin but with a little practice as JJ said this can be overcome. This tendency can be a good thing if one was worried about too much pressure to the wheel motors. But then I really do not think this would be a problem. As time goes on I will report more findings whether they are good or bad. I want to be totally non bias in my findings.
I imagine that having the larger wheel motors might be better in ways and if one was not concerned about losing speed the larger wheel motors I believe would be better. If a person wants to have more torque and only wants to spend about 200 dollars verses the cost of 4 new motors then this defiantly would be a good option. Sorry I did not try this sooner so at least the ones that bought the bigger wheel motors could have had the choice of the two options. Any way most of us do not worry about spending a few extra dollars we just want our machines to work well and do what we need and want them to do. Me? I wanted speed and power. Before unlike some of your machines (like mosses) I did not have. Thanks guys for all your help and comments.
Oh and I took out a big stump that had been on my list for years. I use one of the attachment not meant for stump removal. Can you guess what it might have been. I will report on this later. Where is that thread on unusual uses for attachments?
/ More torque for my Power trac? #80
Hey, glad it worked! :) You going to evaluate it this summer to see if you need/want a solenoid to switch it over? I wish we could dyno test it to see what the actual gains are. Pretty simple conversion you did, really. Nice. :D
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
2019 DODGE CHARGER (A59823)
2019 DODGE CHARGER...
TAKEUCHI TL6R SKID STEER (A59823)
TAKEUCHI TL6R SKID...
