DISC HARROW
   / DISC HARROW #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Which disc go in front, plain ones or the notched ones? and why. This is a 16 disc set up, and I would like to sell it
   / DISC HARROW #2
Hmmm....your pics are hard to see. As I have been told / read the notched blades usually are in front (or front and rear) as they cut up trash better. The smooth blades leave a more even finish.
I just bought a disc with notched blades front and back....lots of trash.
   / DISC HARROW
I would assume that the ball bearing disc are the better ones. What so the other type have ? Bronze sleeve bearings. Which will hold up better in the dirt?
   / DISC HARROW #4
Hmmm....not too sure about that. Most of the little discs made these days (that I have seen....and the one I bought) have ball bearings. I think they are cheaper to produce. But...the sleeve bearings are probably more durable with a longer life (?) and likely are more forgiving without maintenance. If I had to choose one over the other...all else being equal....I believe I'd take the sleeved bearings. My .002
71054 (A49346)
71054 (A49346)
UNUSED Heavy-Duty Ratchet Load Binder/Chain Set (A50860)
UNUSED Heavy-Duty...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2020 Chevrolet Tahoe SUV (A48082)
2020 Chevrolet...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
