which type
/ which type #1
texas law dog
What are the differences with hydrostatic vs synchronized Kioti. Is the difference so great that hydrostatic is a must have?
/ which type #2
Do a search on gear versus hst and you'll find a bunch of threads on this one.
Joel
/ which type #3
What Joel said - but be forewarned - it's a pretty inconclusive debate!!
/ which type #4
Well its kinda like using a car or truck with auto and using a car or truck with standard shift,both work fine,both operate differently,each have advantages over the other.
I like geared things generally speaking,less stuff to tear up,cheaper to replace and buy.But will add,never had a hydro tractor.
/ which type #5
For loader work the hydrostatic seems better (mine is ) the shifting with a clutch forward and reverse a lot will be harder than pushing the pedal heal toe.
Just my opinion and I've ran both types
Tom
/ which type
thanks for the info. I'm purchasing a tractor for the firsttime and I'm trying to educate myself in as manyt aspects as possible. Especially with the uses I will have for it. A friend told me that he had a standard transmission but was synch/shuttle and he said that it was very good and you don't need to use the clutch to shift from forward to reverse. If thats the case I might be leaning toward the manual trans and just go for the DK45S.
/ which type #8
The Kioti DK's are not power shift type transmissions, they have a syncronized shuttle. You can shift between forward and reverse using the shuttle lever onthe left side of the steering column.
But you DO need to use the clutch to shift.
/ which type #9
As Egon said, I would also suggest trying each one out. As a first time purchase, my thoughts would be to lean towards the HST - you can get very precise movements without honing your skill a lot.
That being said, I prefer a standard shift car/truck too. But my car doesn't have a loader bucket on it, either.
I'm sure you will enjoy your new tractor, regardless.
Jon
/ which type #10
Yeah like was said about the shuttle shifter[at least on a ck30],you got to clutch it,its actually a forward/ reverse lever. Only advantage I see in it and just having a reverse on main shifter is it allows different reverse speeds[the faster the main gear you are in,when you put shifter in reverse,the faster you go in reverse].
Like said,don't have hydro,but the only advantage would be loader work that I can see,plus maybe real slow work,was kinda thinking along those lines when I bought mine concerning tilling,but first/low range works just fine for tilling[for me anyways],would probably go a little slower if I could,but than again,now that I know I can till and do a good job at that speed,wouldn't want to go slower.
One thing for you to think over is what kinda tires you want on it before you buy it,ag's or industral,kinda likeing my industrials[so far],but ain't tested them in any real snow or deeper mud. They do have more side ways stability,especially when loaded,in my opinion over ag's,but would say ag's would have to be better in deeper snow or mud. Industrials are supposed to be a tougher tire as far as punctures,but don't know that for sure,mines got 6 plys,don't know how thick ag's are for it.
/ which type #11
I third Egon's advice. Give 'em a try.
I LOVE hydro. This is a debate that will never ever end.
/ which type #12
As others have said, shuttle is different from power reverser, my dozer had the reverser, flick a lever and go from forward to reverse, lots of parts in there though to make that happen.
I hate to bite into this one again but can't help myself, besides I like to hear myself type.
In the end I think if you plan to do a bunch of loader work, hst makes life a bunch easier, less shifting (I personnally don't mind shifting but if I was doing it all day every day, I'm sure it would get old fast).
If not, gear does a more efficient job of transfering the power to the ground.
I went with gear as I was nervous about hst braking (no evidence that would happen, just in case), as I'd much rather replace a clutch plate than rebuild an hst.
As others have said, only way to choose is to try both.
Good luck,
Joel
/ which type #13
Like others have said, your best bet is to try them yourself. I much prefer shifting gears in my car... but I got HST in my tractor. My opinion is that if you have lots of loader or precision work to do.. get the HST. If you have lots of open work, plowing/tilling/mowing, get the gear.
/ which type #14
XlR8 is right on. I have both kinds of tractors. Go HST unless you are doing a lot of field work.
My CK25 is shuttle. I like it fine. But, when going into a heavy pile I find it is slower because in order to make sure I don't ride/burn the clutch and still get a heaping bucket, I switch from high range to low range (which means stopping), usually 1 high to 1 low, or going from 4 low to 1 low before digging into the pile. And have to switch back to transport. This is a lot of clutching.
Of course, if it's light material 4 low all the time works too.
HST is just better for this kind of work as well as for mowing and material handling. Just think if you let your foot slip off that clutch while loading into your truck and smack the side of your truck with your tractor. That should be enought to convince you.
Also with the shuttle, you are like a circus juggler between operating the FEL, the steering wheel, the shuttle, and the gear shifter - hands switching back and forth, up and down. Much easier with HST.
/ which type #15
Can't argue with this post.
Hydro is definitely easier for loader work.
Joel
/ which type #16
I know I would have a lot easier time using my 3 PH snow blower if I had a hydrostat instead of a gear drive. It works fine when I am blowing the drive. But when I try to move the snow banks the town plow leaves by the road I wish I could keep the snow blower speed up while slowing or stopping the tractor motion. With a gear drive when the snow blower loads up and the rpm's drop I need to push in the clutch (which stops the blower) the shift into neutral then let the clutch back out to rev up the blower to clear the snow.
/ which type #18
Your blower stops when you push the clutch because your machine has a non-live PTO.
Most modern gear drives have a 2 stage clutch or Independant PTO. Where the PTO continues to run when the clutch is depressed.
/ which type #19
I understand my machine has two stage clutch, push part way down and I can shift gears, push all the way down and the PTO stops spinning, I've not had a PTO driven implement on so I don't know for sure, but fairly certain that is what my manual states.
Joel
/ which type #20
Joel
Yes, the 3054 and the CK gear models have the 2 stage clutch. (except for the CK 20 gear, it has non-live PTO).
The DK models have Independant PTO. The PTO is turned on by flipping a switch on the dash panel. The PTO runs as long as the switch is turned on, reguardless of the clutch being in or out.
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
2002 WACKER RD25 ROLLER (A59912)
2002 WACKER RD25...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
2023 KMC 3pt 6 Row Rolling Cultivator (A64119)
2023 KMC 3pt 6 Row...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
