one HOT 2305
/ one HOT 2305 #1
lanemc
Member
Lancaster, OH
JD2305
haven't posted on here in a while, but i came across this on craigslist.com & thought some on here would get a kick out of it.
2007 JOHN DEERE 2305 4x4 COMPACT UTILITY TRACTOR WITH 200CX LOADER
just......wow!
gonna be 64 in central ohio this week & although it's a bit early i've started thinking green.
take it easy!
/ one HOT 2305 #3
I don't think it could be fixed. From the looks of it, I wouldn't be surprised if all the seals were ruined from the heat. That was one HOT fire! Some parts would be good like the bucket, ROPS, and maybe the rims (if they're not warped) if you sandblasted them and then primed/painted them. Not much else left of it!!
/ one HOT 2305 #4
Looks like something that should be taken to the scrap yard.
Ralph
/ one HOT 2305 #6
Reminds me of a line from the Beverly Hillbilly's when Pa Clampet was told his car looked a bit rough: "Yeah she does look a bit rough.....Jethro, take 'er around back and rub her down real good with a brick." ;)
/ one HOT 2305 #9
Pictures of burnt machinery can often be misleading. Since heat goes up, and if there is nothing under it to fuel the fire (like diesel), then there may well be some salvageable parts. I know if I had a 2305, I would seriously be looking at those pictures, in case I tore up a ring gear in one of the axles, or maybe a gear in the tranny. Parts partially submerged in oil are most likely able to take a lot more heat than the sheet metal, and it appears to have withstood the heat without warping too badly.
I am currently taking a 4100 apart that suffered the same fate, but it was "next to" the barn, and actually had some green paint still on the loader cylinders, which tells me it didn't get as hot as the pictures of it showed. Somebody is going to get a good deal on some four wheel drive tractor parts from me.
David from jax
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
(2) FORESTRY TIRES ON RIMS (A64276)
(2) FORESTRY TIRES...
FORD GT95 RIDING LAWNMOWER (A64281)
FORD GT95 RIDING...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
John Deere Worksite Pro RS72 (A64119)
John Deere...
