Another remote valve thread..
/ Another remote valve thread.. #1
tatra805
Okres Pezinok
Iseki TL1900FD
The grapple thread went a bit sideways but i would like your confirmation on my setup.
Attached the setup i want to install. Are things correct?
CYL 1 and 2 are the dumping cylinders of my trailer.
CYL 3 the grapple
RS stands for rychlo spojka what means quick-connect overhere. I used the drawing to get my order explained in Slovak :eek: :p
The extra non regulated output i want to have to attach eg a logsplitter or other device with its own valves.
Cylinders and valveblock are bought, hoses ordered. To make the complete setup i need 28 meters :eek: of hydraulic hose and about 24 fittings. awaiting the price offers as we speak.
I opted to mount the valves next to the FEL valveblock so all controls stay grouped. Although these tractors are a small place altogether i would hate to have to swing my arms all the time.
Had to skip on the float function. The valveblock costs about 150 USD (Slovak production) while a block with float (German import ) was.... tripple that!! :(
Pics might follow later as things get installed.
Edit: maybe the drawing (if correct) might help some other newbie to get the picture. It took me weeks of staring at my joystick and reading TBN to figure it out...
/ Another remote valve thread.. #2
Your drawing is correct provided that the two RS connections at the bottom connect to the machine properly-but you did not detail that.
/ Another remote valve thread.. #3
I am not with Kennyd on this one, maybe I just am missing something. It looks like you are dead heading the PB to the bottom RS quick connect. By that I mean the full pressure in the PB port is going to the quick connect all the time with no way to turn it off / on other than to stop the tractor. When the RS is not connected and flowing, it will be continuously popping the pressure relief valve (that you don't show) in the valve block leading to smoking hot fluid, pump and possible seal failure.
A better solution would be to have a control valve on the PB line before the bottom RS. An even better solution is to have a 3 spool valve that controls the fluid to the remote.
jb
John Bud, reading your remark i see it also....
So something like this could work?
Can the extra valve (suposing it is OC) be a settable flow regulating valve?
Something as a ball valve which you can leave in any position (when nothing is connected it should be closed of course) eg to drive a hydraulic motor at a settable RPM ?? (whats the name of such a valve?)
Something like this?
http://www.surpluscenter.com/item.asp?UID=2009021007222165&item=9-4341&catname=hydraulic
Lots to learn...
/ Another remote valve thread.. #5
jb
That is why i wrote this:
I ASSumed it was connected back to the tractor properly at a manifold or something. The valve is not needed if the PB line feeds another valve (like the 3PH on most machines) and it's NOT disconnected while the machine is running.
Just like adding in a backhoe...
/ Another remote valve thread.. #6
Right. But he didn't show a valve and it looked like he thought one wouldn't be needed. Could be wrong -- it has happened!--
Tatra -- The PB port has 100% full flow going thru it (except when the flow is diverted by the valve actuation, used then sent to the "return" port). So, no. The valve in the diagram you drew can't be a flow regulating valve as it would be getting 100% of the flow from the PB port. But, yes, the valve you linked should work as a control for a rear remote that is used to run a hydraulic motor. The pressure that valve can take is fairly low, but if that's ok then it should be good to go. If you are using the hydraulic flow for the 3ph, you will need a PB port on the LAST valve plumbed to the 3ph.
With everything, there are multiple ways of doing it sucessfully. If you want to dedicate a % of the flow to valve #1 and the rest to valve #2, you need to split the pump output flow BEFORE the valves into 2 flows. That would regulate the flow between the devices (loader and rear remote). I wouldn't want to do it that way as you typically want more flow for the loader and hydraulic motors.
The most elegant way would be to mount a 3, 4 or 5 spool valve in the middle of the tractor and control the loader with a cable joystick mounted up by the steering wheel. And the remotes by either cables controls or hard links. Then only one valve is needed.
But in all honesty, there are others here with more experience doing this than me!
jb
/ Another remote valve thread.. #7
Burden Sales Surplus Center Item Detail
I'm certainly no expert in this arena... but the RS tripped a red light for me too! What are you planning upon doing with the PB junction at RS?
I'm not real clear about the 2-way valve as well. As diagrammed, the valve has 2 PB inlet ports (one routes to RS- blue line) and one PB outlet. I've never seen a valve body with 2, PB inlets.
Is the plan to use a variable-flow valve to operate a hydraulic motor? Many hyd motors are big GPM hogs. Seems like a 2nd, series mounted valve with PB circuit would be needed.
Lots to learn as well...
AKfish
/ Another remote valve thread.. #8
I think by "2-way" he means "2-spool"...
The ports on the valve not marked are IN and OUT.
Thanks for the input, trying to follow...
John bud you write: "The PB port has 100% full flow going thru it (except when the flow is diverted by the valve actuation, used then sent to the "return" port)."
Is it my misconception that the PB port differs from the return port by the fact that it diverts the high pressure flow side and thus not interrupts the supply of all valves that are connected to it?
Otherwise its function would not differ from the return line? As in an OC system the flow continues goes from IN to OUT and is only interrupted when a spool is opened and requires flow while shutting off the return line?
KennyD,
The 3pt is positioned as in the drawing, which is actually last in line. That would make the flow valve not necessary if i follow your comments.
but i dont see how the RS would get any pressure as long as the 3pt is OC flowing.
So this one is better?
/ Another remote valve thread.. #10
OK, What are you trying to do with the RS fittings at the bottom of your drawing?
The first picture in your last reply is 100% correct except for that RS at the bottom going nowhere...
Kennyd,
Hard to explain, i would say as an example a log splitter with own control valve (OC).
or say i have a transport belt driven by a hydraulic engine without speed control just on/off. Then i need a on/off valve on the tractor.
Add to this speed control, then i would need a settable flow regulating valve on the tractor.
I see a lot of devices with hydr engines that have no valves just the 2 hose for direct plug in and no need for speed control.
If i need to attach something non continues as hydr cylinders, say the up-down left-right moving things i can use the output i use for the cylinders of the dumptrailer.
So i saw these bottom RS connections as a continues high power output. I did get the safety point that it would be better to be able to switch this exit and i added the settable flow control as a speed regulation....
/ Another remote valve thread.. #12
For a logsplitter or another device with it's on valve you would put it in series with the PB line at the bottom before it gets back to the 3PH.
-You cannot Tee into high pressure lines...
-All valves must be in series...
You setup would look like this in the attachment...Where the RS couplers at the bottom are joined together unless you added in something else.
Sorry for messing up your beautiful drawing!
Thats what drawings are for!
Now, it all started to make sense till I called my dealer at the other end of europe asking him how he is plumbing things..
I should first mention he knows PB ports and tractor hydraulics quite well but sticks to this simple setup as he had too many customers running into problems with complex plumbing.
He says to plug in as in the drawing, meaning a series of valves but no use of PB ports.. now i get confused again...
The restriction would be that you can only operate 1 spool at the same moment. Not a big issue to me if i think about it. 1 drawback would be that the hydr. motor would stop when moving the fel or something else.
objections?
/ Another remote valve thread.. #14
objections?
Here is the remedial hydraulic question. If you can plumb it this way what is the use of PB? What is the difference between the return line with out power beyond and the the PB when installed?
/ Another remote valve thread.. #15
objections?
I object. You really should use the PB, that is what it's for.
That way also can put very high pressure in the OUT port of the previous valve in the circuit-which most are not designed for.
/ Another remote valve thread.. #16
Not using the PB can put very high pressure in the OUT port of the previous valve in the series like a mentioned, and it also cut's the flow to downstream valves when one of operated. It is really a less than ideal setup.
/ Another remote valve thread.. #17
KennyD,
The drawing that is remaining is the "correct" way to do it with one exception. The box "FEL" is not doing anything and does not need to be there as the box "2 spool valve" is performing that function.
Couple "clear ups".
The "out" also called "return" ports on hydraulics is for what I call used fluid. That is fluid that has had the high pressure used up. It will be at a low pressure, typically under 1-200 psi and often down around 50 psi. You can't use that flow to power stuff as it NEEDS to be a low pressure fluid. Some people may "cheat" like you showed and they may even get away with it for a while, but it will catch up to them with leaks and possible valve damage. When you use the valve to power something, ALL of the fluid from the pump is redirected. The "used" low pressure fluid is returned to the reservoir and NO FLUID goes out the PB to the next circuit downstream.
The PB or Power Beyond port is used to supply hydraulic power BEYOND or after the valve. It is built to contain the full pressure of the pump. If you put valves in order 1, 2, 3, etc and the next higher number is powered by the PB port. When #1 is used there is no flow to the valve #2, 3, etc. People sometimes will see this when the loader or 3pt is used at the same time and one of them doesn't work. In slightly different language, If you don't use the hydraulic power in device #1, you can direct it with the PB port and use it in device #2. If you don't use the hydraulic power in device #1 or #2, you can direct it with the PB port and use it in device #3. and on down the line.
It's hard to explain these concepts over a keyboard with no feedback, so sorry if you already know these things. Not trying to talk down, just trying to give enough examples that it is clear. Hope it helps a bit.
jb
Thank you all for the feedback. It keeps amazing me how beneficial internet and sites as TBN can be.
John Bud: The FEL valve is the one on the tractor now operating the FEL and the 2 spool i want to add for other applications.
I was blowing the valve while operating things to find out the functioning a bit. (hydraulic oil has no taste..)
WHEN BLOWING A EXIT PORT OR THE PB I HAD SAME RESULTS
So i called the manufacterer of the 2 spool valve i bought. Long text but maybe interesting to some. Friendly patient man...
My valve has a PB port, 2x IN and 2x OUT.
His explanation was:
2x IN and 2x OUT : for mounting convenience one on top and one on the side of the valve block.
PB port: on simple valve designs such as standard spool valves (1-2-3-4-... spool) The internals of the block allow for a the PB to be nothing more than a extra OUT connection and function as such. The valveblock is made upto the task.
In more complex valve designs where most of the time the same base block is used the internals are made so that indeed a hole needs to be plugged with a PB plug (which blocks internally the flow to OUT) and the PB port gets a dedicated flow which is "separate" from the normal OUT exits.
To drive it home: They have x types of casts (the base blocks) which are machined to Y basic blocks.
These basic blocks are then further configured by the internal parts (separate parts building up the valves) and secondly extra machining eg drilling through an internal wall to make an extra oil passage as needed by a type of valve configuration.
In the case of pluggable PB this plug is closing one of these extra machined passages. In case of the standard spool valves this passage is not there and therefore does not need to be plugged.
On the remark of valve damage and leaks in case of a "wrong" out-to-in configuration he went :rolleyes: but gave a nice simple clear explanation:
Imaginge the main oil stream as a TUBE.
All internals are made to cope with the pressure. The oilway from In to Out or In to PB is nothing more than a "tube" in the block which is also designed for these pressures. The only thing that could happen when pressurizing the complete tube with a plugged exit is the plug breaking.
In the old days a safety valve was a plate with breaking lines in cross form, so when overpressure happened the plug would break and let the oil flow out.
Now when connecting in series (out to in) what will happen? Your "tube" is just longer going from hose to valveblock to hose to valveblock to exit. If you operate the last valve in line the whole "tube" becomes pressurized. So what? If your hoses and connectors are right... nothing.
Same happens when making the "tube" from hose to In to PB to hose to IN to OUT.
PB ports are a result of something, not a cause. Everybody sees them as necessary and people are educated that way.
PB is the result of complex valves that need internal flow to be redirected internally and physically/mechanically design preventing to use the OUT port as exit.
If you have a simple valve design that does allow to use the OUT port why would you make it complex and make a dedicated (useless) PB design??
We have them on our simple valves because of universal machining in our production and... to avoid calls like this.
This might stirr the pot a bit but it also made sense...
/ Another remote valve thread.. #19
Well, you are getting more of an education than anticipated! Glad you are sharing the information with us. I for one only have "some" understanding, based on the valves I've played with being the type with the plugable PB port. The explanation given to you sounds plausible, and it's your $$ and tractor.
Keep us in the loop as you progress.
jb
Had no internet connection for a couple of days so loooooots of time for plumbing hydraulics:D
Pics to follow when servers are back running completely.
So, i installed the hydraulics as in my last picture going from the explanation of the manufacturer regarding the PB ports.
Things work a charm.
The shop did not have a second valve block in for the rear-command so i looped it at the moment.
Tried out the front and backs and i do not seem to have a problem. Also, when operating the FEL i am still able to use the grapple control.
I would recommend everybody to install a pressure gauge immediately it just shows things so clearly.
What i found:
- System pressure 250Bar (! so good for a 15 year old tractor)
- FEL command stops flow at end of stroke while maintaining pressure in cylinders. The new valve block does not do this. Because the safety valve is set too high? I have no idea how this works.
- Idle pressure is between 50 and 75 Bar with the 3pt set at all positions but completely down or at the presettable down position (i have 2 3pt controls with 1 being a presettable low position). I suppose this is normal.
- Trailer is dumping full loads of dense, wet heavy manure. Pressure rises to 150 bar at start of dump to 100 bar at end of dump. Happy camper.
- I quickly fabbed a grapple and although it is working will need to reinforce it a bit as i greatly underestimated the forces of this small hydraulic cylinder.
Some advise to others:
- Measure your hoses precisely and then do it once again. Being on the long side is good but too long not. (ask me) A trick is to use a piece of rope to make your routing and then measure the lenght of rope.
- Install the hoses on the valveblock before putting it on the tractor. Tight spaces and long spanners are a pain.
- install a pressure gauge. if not then 2
- Do not tighten any connections (except the valve block) till all hoses are in place. It will avoid tension on the hoses and make routing them MUCH easier.
- Pressurize the system the first time on your lawn and not your driveway. Hydraulic oil is a pain to clean. Leave it sitting overnight and check for leaks in the morning (i had a leak showing only the second day, probably after all air was slowly purged)
- Check your oil level again after a couple of hours of operating.
- Keep being aware that you are working with Hydraulics, dont understimate the power of it. I would strongly advise to make your test run alone and with all things mounted as should be and sitting in the drivers seat.
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
2011 Ford F-550 Truck 4x4 (A62613)
2011 Ford F-550...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
Steel Wheelbarrow (A65640)
Steel Wheelbarrow...
2019 PITTS CONTENDER LD35-22DC RGN LOWBOY TRL (A64277)
2019 PITTS...
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
