Mahindra 3510. Overheating
/ Mahindra 3510. Overheating #1
brow1033
Hutchinson, KS
Mahindra 3510
I have been reading all the posts since I ran across this site. I am at wits ends with my overheating problem. Seems like I can't seem to clean the radiator and screen enough to keep from overheating. It is no fun knowing I can't work for an extended period of time. Any help is appreciated...
/ Mahindra 3510. Overheating #2
It may help if we knew what you are doing that causes the radiator and screen to plug up so quickly.
I assume you have checked the antifreeze fluid level in the radiator.
Have you tested or replaced the thermostat. It could be getting stuck partially open.
How old is the tractor and if over a couple years have the radiator and motor ever been flushed out and antifreeze replaced.
Providing nothing is wrong with the motor, overheating is usually caused by an improperly working thermostat, low fluid level in radiator, blockage or restriction in cooling circuit internally or blockage of the radiator fins not getting adequate air flow. I suspect the thermostat.
/ Mahindra 3510. Overheating #3
Also check for a loose or faulty/slipping fan belt.
Sometimes blowing a radiator out can push debris back into the radiator fins eventually blocking the airflow.
A few things to check for.
/ Mahindra 3510. Overheating #4
I have seen some tractors that had so much debris in the radaitor fins that cleaning in the tractor was an impossibility. Taking the radiator out of the tractor and pressure washing it was the only cure. I don't know what your history as far as cleaning methods and intervals has been, but like I said, I have seen them so plugged up with fine debris in the fins that you couldn't see it or clean it in the tractor. Just a thought.
/ Mahindra 3510. Overheating #5
If it is just the radiator clogged up then it needs a good cleaning. I personally wouldn't recommend pressure washing because it is easy to flatten out the cooling fins and cause even more problems. Cleaning it from the engine side out is best since most of the debris will be on the front of it. They do make products to help "draw" stuff out of it.
/ Mahindra 3510. Overheating #6
I agree with the power washing, unless one is pretty careful it wll bend over the fins. They do make a comb to help starighten it out a bit though. I get alot of airborne weed like particals from bush hogging w/mine. Maybe once a year I get the leaf blower out after it. Supriseing how much dust comes flying out. I blow it backwards, opposite of the fan pull also.
Does your fan pull air through really good? With mine running, you can tell the fan moves a bunch of air when taking the side engine panel on or off. Other then an air restriction or water restriction, make sure the radiator is full. Good luck, I know a tractor not performing 100% can be a real pain.
/ Mahindra 3510. Overheating #7
Yes the power washing can be a little risky if you have to much pressure. The ones I have done this to have had very fine debri in them and when a quick garden hose cleaninng was done this stuff hardened in there like concrete. I don't know but this could be your problem.
/ Mahindra 3510. Overheating #8
Never an overheating problem with my 3510. I do keep the engine compartment relatively clean using compressed air with a horsehair brush to remove excessive dirt & dust. Then I use an electric pressure washer to wash the radiator from the inside out. Zero problems so far with this approach.
Rusty
/ Mahindra 3510. Overheating #9
I've found a good heavy duty leaf blower will help clean alot of loose debris out. I use it around the engine and radiator....the whole tractor to blow away stuff
Mainly for dust or to avoid the dust to concrete buildup referred to above.
/ Mahindra 3510. Overheating #10
Here is the problem with radiators in tractors used for field mowing. Plants contain sugary starches. When heated, those do congeal into the solid mass they were before they hit the radiator. The debris enters primarily from the front. I like Talcott1's idea of the leaf blower; which also makes a great chamois after washing your beast.
I just recently replaced my battery. When doing so, I especially noticed all of the radiator fins behind the battery compartment were plugged with hardened plant dust. Using compressed air, I was able to carefully blow out the clogs from the front, thus forcing them toward the engine. Next time I do this, I thing I will take the time to remove the fan shield. Doing so will enable me to get my air gun into a position to blow the dust from which direction it came.
/ Mahindra 3510. Overheating #11
I can sure attest to what is said here. I have the 4110. Last year it was overheating very easily when running the bush hog. I eventually took out the radiator and pressure washed it. To say there was a lot of debris in the fins was an understantment. There is no way I could have cleaned this out correctly with the radiator still mounted.
Also, I had no problems with using the pressure washer to clean it. Just be carefule and spray at 90 deg. to the face of the radiator and you will not bend the fins.
After the cleaning the tractor has never over heated.
360 hrs of mostly bush hogging on it
/ Mahindra 3510. Overheating #12
Brow1033,
Have you tried this? I posted this in one of your other threads,but it may have gotten buried......
Assuming you have eliminated the obvious items as already posted, Are you willing to try a $7.00 experiment? (this assumes you do the work yourself).
I had a similar problem with my 30 plus year old Kubota which I purchased used. Darned thing always wanted to run warmer than it should. Of course I checked the obvious items to no avail - even down to the radiator cap. Replaced the temp gauge and sending unit just to ensure that I had accurate gage readings. So I thought lets put a new thermostat in which was $23.00 from Kubota Dealer . The brand new thermostat from Kubota made my problem WORSE. I returned the Kubota thermostat and got my money back. What I noticed about the Kubota thermostats is that the center popit was very small almost to the point of being excessively resrictive in my opinion.
So I went to my local NAPA dealer with my old thermostat in hand. From their picture/dimensional book, I picked a thermostat 10 degrees cooler than what was stamped on the Factory Kubota thermostats and also looked for a thermostat with a bigger center poppit valve which I hoped would increase water flow some. I did have to grind the outer ring slightly so it would fit in my water jacket receptacle, but this was easliy done on a bench grinder by hand. IN SHORT, A $7.00 Thermostat that fit some oddball Diahatsui car is now in my Kubota and it totally fixed my problem. I did this 10 years ago and I still have the tractor today with my custom thermostat in it. My tractor now operates in the temperature ranges that it should because one needs to realize that an engine operating at too cold a temperature is a bad thing as well. (My tractor originally had a 180 degree thermostat and I opted for a 170 Degree thermosat. 170 degree is not a common selection but it is offered. I did not want to drop all the way down to a 160 degree for fear of engine running too cold. The bigger poppit allows for more water flow which I think helps matters too.)
(Special Note: Do not attempt to run it without a thermostat whatsover. If you are truly at the end of your rope, then this would be a $7.00 experiment worth trying in my opinion.)
/ Mahindra 3510. Overheating #13
I agree the radiator should be throughly cleaned after each use. Debris is a major overheating in almost every case I have looked at.
Another thing to look at is the battery placement some early models had the battery mounted high, and it was blocking a good portion of the bottom of the radiator, Manhidra has a fairly low cost battery relocation tray that drops the battery about 6-8 inches so the top is at the bottom of the radiator
Good luck, but when I used to have a 4110, I could run it all day in 80+ f days with not overheating it would not even get to the mid point
/ Mahindra 3510. Overheating #14
A couple of odd ball possibilites.....
Wrong coolant mix. Most mfrs recommend 50-50 to 70-30 mixes. Pure water cools best, and the cooling ability, not boiling point...actual heat
rejection capacity drops as you raise the anti-freeze percentage.
Contrary to some people's opinion, a 100% anti-freeze level can cause
overheating. Another rarity would be the water pump impeller spinning freely on the pump shaft. Both have happened to me......
/ Mahindra 3510. Overheating #15
Same thing here. 4110 started running hot after cutting an overgrown field. I remember it only took 15 minutes to clog. Blew out chaff and 15 minute later hot hot! It was quite a few acres. I waited for a light rain and cut it all. Rain stopped the dust. However, I could never bring the temp down to where I thought it should be.
Well, bad luck turned out to be good luck. I developed a small radiator leak. Of course, being a cheap a**, I tried stop leak and some other things. Really I'm lucky I didn't burn up tractor then. One day my brother-in-law decided to help me cut the grass; while I was away. He thought he'd surprise me. Problem was the machine needed water and driver never noticed gauge. I came home while he was still cutting. I checked and temp was to peg. We shut it down and I added water later. Started her up and ran ok. LUCKY ME. I pulled the radiator and sent it to radiator shop. Radiators are cheaper than engines. It ain't worth it to Mickey Mouse around. Course i like Mickey; he always smiles.
The old radiator came back like new and was CLEAN. Temp rides right where it did when new. If I have to cut a few high weeds I'll back into thme. If I have to cut a big field of high grass I'll wait till grass is wet.
Cheers...Cofeeman
/ Mahindra 3510. Overheating #16
I am very confused here. I posted in this thread two weeks ago and my post is gone. PM and I will be happy to come take a look at the situation. Who did you buy from? Have you removed the radiator for cleaning? My guess is that it is still packed full.
/ Mahindra 3510. Overheating #17
The earlier models had the battery mounted high and nearly covering the radiator fins.
Mahindra has a conversion kit that drops the batter down. I found at Bill's Tractor on the web.
Bill
Stout Buckets XHD 84 Grapple Skid Steer Bucket (A65640)
Stout Buckets XHD...
(75) Square Grass Hay Bales (A66408)
(75) Square Grass...
2013 Polaris Ranger 400HO (A66408)
2013 Polaris...
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
2014 RETESA 210BBL CRUDE TRAILER W/ PUMP (A65643)
2014 RETESA 210BBL...
2016 John Deere 6155R (A64119)
2016 John Deere...
