CAT 2 implement to CAT 1 tractor
/ CAT 2 implement to CAT 1 tractor #1
Gittyup
Elite Member
Mid Atlantic
Kioti CK25 Shuttle Shift, loaded tires, JD X739
Read through the few threads that talked about this trying to understand. But, after trying it, still confused. My CAT 1 top link pin just falls right through the holes in the CAT 2 implement. Read a thread about using 3/4" pipe on both sides of the toplink ball. But, how does this keep the top link pin from falling out? Can't find a "fat head" CAT toplink. Obviouisly, I'm confused.
/ CAT 2 implement to CAT 1 tractor #2
Depending on the pin, maybe washers at the outboard side, to keep it from falling out? Bushings to keep the pin from having too much slop might be a good idea.
One good thing about using cat II implements on a cat I tractor, is your not as likely to tear anything up, provided the tractor can stand the weight.
David from jax
I'm thinking about welding in a piece of pipe in the holes so that the implement is effectively CAT 1. Seems logical given that I'm using CAT 1 draw pins anyway.
/ CAT 2 implement to CAT 1 tractor #4
Definately need to use washers on each side.
I cut some sections of 1" pipe and welded into the holes today. Then ground them fairly smooth. I've ordered CAT1 draw pins with 1 1/8" threads. When they are installed it'll be a CAT1 implement. Still not there yet; need a longer top link pin.
/ CAT 2 implement to CAT 1 tractor #6
Just go to your local farm supply store and buy the bushings that will convert category 2 to category 1. TSC has them and they are specifically made to convert from 2 to 1. I bought some and some spares the last time I was at TSC.
I have a couple of the bushings. But, aren't they really to adapt a CAT2 3PH to a CAT1 implement? A floating bushing isn't going help keep my toplink pin in place. The spacing between the toplink support holes is 3 3/4". So, I'd need two just to fill the space. And I would still need a washer. I am trying to stay away from the washer option.
I suppose I could've welded in pieces of the bushings instead of pipe. I had the pipe and I thought it better to cut it down rather than a perfectly good bushing. Besides, I need the bushings to adapt the CAT2 top link I just got.
/ CAT 2 implement to CAT 1 tractor #8
"But, aren't they really to adapt a CAT2 3PH to a CAT1 implement?"
Yes you are correct, I simply misread your post! I will go sit in the corner for a time out now. Sorry!
No Problem. Appreciate the help anyway.
/ CAT 2 implement to CAT 1 tractor #10
Don't over-think this...Get a fender washer.. actually 2 of em.. one for the head side.. one for the lynch pin side... easy eh!
soundguy
I know I can use washers. Just don't want the extra parts. Anyway, it's done now. Implement is now CAT1 thanks to the welded in bushings. No washers required.
/ CAT 2 implement to CAT 1 tractor #12
I have a slightly different problem. I would like to use a cat 2 quick hitch on my cat 1 tractor, so that I can remove my 8' brush cutter more easily. The cutter has holes for both cat 1 and cat 2 pins, but the spacing is about 32", or clearly cat 2 category. But my tractor is cat 1, and the lower arms will not fit cat 2 pins. The upper link is no problem; my toplink has one of those cross drilled balls that are cat 1 one way, cat 2 the other way. My tractor can lift over 3000 lb, so the cutter, at 1600 lb, is no problem for it. But how do I attach the lower links of the 3-point hitch, with 7/8" holes, to 1 1/8" pins?
/ CAT 2 implement to CAT 1 tractor #13
I would try short 7/8 x 1 1/8 bushings on each side of the 7/8 pin. Put the bushings into the quick hitch frame first, then insert the lower arm and put a 7/8 pin through. Adjust with washers, etc, so nothing can work loose.
Bruce
/ CAT 2 implement to CAT 1 tractor #14
Not sure that will work. The quick hitch uses a special pin which is barely long enough inside the frame holes to accommodate the link ends.
/ CAT 2 implement to CAT 1 tractor #15
You wouldn't be using the quick hitch's pin anyway. It would be too large. Use an aftermarket 7/8 pin that is longer.
If I am misunderstanding, a photo or link to the quick hitch maker's site would help.
Bruce
/ CAT 2 implement to CAT 1 tractor #16
One example: 3 Point Quick Hitch
The image does not show the side that faces the tractor. But any bushing would have to stay in the hitch holes without sliding off, and yet be narrow enough to let the 3-pt arms fit. I would have to lay this out. I don't have all dimensions.
/ CAT 2 implement to CAT 1 tractor #17
My idea is to use bushings to temporarily convert the Cat 2 quick hitch mounting holes to Cat 1 size. (unless this is to be a permanent conversion)
Here is a crude drawing of what I mean. It would need the extra space taken out of the system with washers or a new lynch pin hole. (or use a bolt) Bushings could be cut shorter, too.
Bruce
/ CAT 2 implement to CAT 1 tractor #18
Actually, that is a very clear sketch. My concern would be that the bushings might slide out of the holes unless all the lengths were just right. But a quick tack weld of the bushing to the pin might fix that.
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
5-Pointed Star Metal Decorative Sign (A64557)
5-Pointed Star...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
11in. Bucket w/ Teeth Excavator Attachment (A64194)
11in. Bucket w/...
2014 Honda Accord Sedan (A64557)
2014 Honda Accord...
