Need for Building Codes!
/ Need for Building Codes! #21
Wow, just wow. Anybody can be an electrician i guess :rolleyes: And the inspector saw that and did nothing? If an electrician saw that and did nothing, he could be on the hook and lose his license if anything "bad" happened. Can you say liability?
/ Need for Building Codes! #22
A little off subject, but still a big federal no no.
Don't know who took the pic.
/ Need for Building Codes! #23
:D Ok ill bite. What am i Missing? Maybe I dont see because I dont deal with refrigeration. LOL
/ Need for Building Codes! #25
What are we looking at here, cigarette smoke, low cloud, freon leaking, line not crimped, what?
being as he said that it was a "Big Federal no no" I would assume that it is freon leaking from when someone ripped the outer set of tubes loose.
Aaron Z
/ Need for Building Codes! #27
Joe, I thought you knew better . You aren't suppose to do it the ol fashon way anymore:D
On the electrical issue. If he could just get a cover on the box, He'll be ok:rolleyes:
/ Need for Building Codes! #28
Ill bet ya it was at the distributes ware house and given the location in the coil and it's still o a skid and that is too clean inside they put a fork in to coil and were patching it up to sell t one of us.
tom
/ Need for Building Codes! #29
With a wire mess like that you need a good smoke alarm like this.:)
/ Need for Building Codes! #30
The amazing part is that if the person who did it was smart enough to organize all the wires to work and run equipment correctly, you would think they would be smart enough not to put it all in one box!:rolleyes::eek:
/ Need for Building Codes! #31
Maybe he thought, if I run these wires through a central distribution box, I should be OK.
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
WACKER NEUSON LIGHT PLANT (A65643)
WACKER NEUSON...
John Deere 4955 Tractor (A66285)
John Deere 4955...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
Case SV280B (A60462)
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
