Flail Mower How to measure flail mower blades
   / How to measure flail mower blades #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I just purchaced a Lawn Genie mower and have to replace 5 missing blades. What is the proper way to measure the length of the blades. Do you stand the blade up verticle and measure the height or do you measure the actual length of the blade. Also if you have a 3" long blade do you have to specify where the bend is.
Bill
   / How to measure flail mower blades #2
Don't know but you could call someone at AgriSupply for advice.
   / How to measure flail mower blades #3
Bill
I match my blades to the dimensions shown in the supplier's catalog. Also look for consistency in cross-over brand/model notes. I have a Land Pride mower, which is not directly listed by aftermarket suppliers but dimensionally similar to certain Vrisimo blades based on catalog drawings.
   / How to measure flail mower blades #5
Lawn Genie was manufactured by MATHEWS COMPANY out of Crystal Lake, IL 815-459-2210. mathewscompany.com Blades are available from them via a local dealer. Check their website for your nearest dealer. Part # for the blade is 131 4465. The new blades have a square shape compared to the original which were tapered. They suggest replacing in pairs and opposite sides. An online manual is available for your model under their resource heading.
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
LINCOLN WELDER (A55745)
LINCOLN WELDER...
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
2016 PETERBILT 367 SLEEPER (A55745)
2016 PETERBILT 367...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A57024)
PENDING SELLER...
