2810HST will not start
/ 2810HST will not start #1
coachcarter
Elgin, TX
Mahindra 2810 HST
I am a newbie and need some assistance. I have a 2810HST and it will not start. When you turn the key to start nothing happens. Here's what I have checked so far.
1. The battery is ok - actually it is brand new.
2. PTO is not on.
3. Tractor is in neutral.
4. Voltage on the battery drops when the key is moved to start.
What else should I try? Thanks.
/ 2810HST will not start #3
I've recently had issues with the switch on the parking brake pedal. Wiggle the pedal and it will stay running. I plan to look at it this weekend.
/ 2810HST will not start #4
I had the same problem. Tore out the dash and checked the switch. that was ok it ended being corrision around the positive battery terminal. Clean both, also checkthe fuel shut off solonoid. Had mine stick in the wrong position not allowing fuel to pass. You will hear a buzzing noise in the solonoid. good luck -- John
/ 2810HST will not start #5
2. PTO is not on.
Sounds a lot like a loose/dirty connection. Start at the battery and check all necessary connections to make sure they are clean and tight.
/ 2810HST will not start #6
I once had a non starter when an electrical contact came off the side of the transmission housing, under the seat area- this registered that the tractor was in neutral. Hard to detect though because the contact was hidden under a wee waterproof rubber hat. It's a great way to disable the tractor quickly if you want to make it safe from thieves, often do it when rainy day makes the descent of the mountain track dodgy - hairpin bends etc.:eek:
Darren
/ 2810HST will not start #7
Is your right side brake on?
I wonder; If one is driving tractor and the switch would malfunction, would tractor shut down? In addition, would this present a safety problem?
Cheers.....Coffeeman
/ 2810HST will not start #8
Mine has recently. More of a hassle than anything else.
/ 2810HST will not start #9
You've gotten lots of good ideas here, start with your battery connections, starter connections. Then check safety switch on the bottom of the seat. These things can be done rather easily. After you've gone that far things will get a little more difficult.
/ 2810HST will not start #10
Another excellent suggestion. I was leaving the seat up in wet weather to avoid sitting in a puddle. What happened was moisture in the seat safety switch. I tried WD-40 with limited success but, compressed air was better. Depress the plunger and blow it out.
I will try the suggestions this afternoon. Thanks for everyone's responses. I will keep you posted.
Here's what I have checked:
1. Disconnected the battery. Cleaned all connections. Reconnected the battery.
2. Checked the voltage at the solenoid. All good.
3. Checked the safety switch under the seat.
4. Checked the parking brake - removed the dash so I could see the switch.
5. Checked th fuses for the PTO/Stop and Glow.
Even solicited assistance from my neighbor :). The tractor still will not start. Any other ideas on what I should check? Thanks!
/ 2810HST will not start #13
is the shuttle shift in neutral?
is the clutch safety switch bad?
and not to sound condescending, but are you sure the PTO off? (voice of experience)
if yes, that safety switch could be bad as well.
Yes, the shift is in neutral.
Checked the clutch switch (easy to check with the dash torn off)
The PTO is off.
/ 2810HST will not start #15
the only other thing I can think of is follow the wiring harness from the alternator out - there will likely be a fusible link that's blown. (had similar problem with my Century 2535 when a field rat took the 6" section of wire with fusible link for his nest one night)
/ 2810HST will not start #16
How long was that before he came and took the whole darn thing? ;)
Good ideas here so far though. Have you double checked the neutral safety switch? I am not sure how that one is setup, but I have seen the neutral and PTO safety switches make people wanna pull their hair out. You seem to be calm, cool and collected so far. I would have thrown so many hammers by now if it were me...:mad:
/ 2810HST will not start #17
All good suggestions so far. I assume when you say nothing happens when you turn the key you mean it does not crank over. Hook a test light or meter to the starter solenoid to see if the small wire is getting power when you turn the key. If no power to this wire then it may be a blown fuse, fusible link, or a safety switch in series holding it out. If you are getting power and no crank it could be the starter or solenoid. With the key in the on position have you tried jumping the starter to make it crank.
/ 2810HST will not start #18
The original poster has said the voltage drops when he tries to start, so that means that the solenoid or starter is drawing current. Check the starter and see if it is warm after trying to start.. Tap the starter with a hammer. The pinion gear may be stuck. Remove the starter and test with battery cables. Do you have a separate solenoid. Take the cable off the starter and and try to start, now see if the voltage is dropping on the starter side of the solenoid..
/ 2810HST will not start #19
I agree with George. If you have a test light it will definitely help. Checking the small power wire at the starter when you turn the key to the crank position will tell you a lot about where the problem could be.
When you say that you turn the key on the voltage drops... what exactly do you mean. When I first read it to me I was thinking you lose all power which is why I initially said that it sounded like a connection problem. If that is the case then I still think it is a bad connection. Check the ground at the other end of the battery. It should be bolted to the frame, engine block, etc.
/ 2810HST will not start #20
He never did as I suggested, and that was to put jumper cables on the starter and see if the starter will turn.
2025 Swict 66in Bucket Skid Steer Attachment (A66734)
2025 Swict 66in...
2022 Ford F-250 Knapheide Service Truck (A66736)
2022 Ford F-250...
2018 CHEVROLET SILVERADO REGULAR CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
PORTA POTTY (A68842)
2017 Bobcat MT55 Ride Behind Track Loader Skid Steer (A66734)
2017 Bobcat MT55...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
