Getting tractor to the dealer with front loader attached
   / Getting tractor to the dealer with front loader attached #1
aemiller4
Assuming I am not able to troubleshoot the electrical problem I am having. I am trying to figure out how to tow my tractor to the dealer with the front loader still attached. The only thing I can figure is that you would have to drag the tractor backwards onto a flatbed, dragging the bucket on the ground the whole time.
   / Getting tractor to the dealer with front loader attached #2
Or jack and chain it up.
   / Getting tractor to the dealer with front loader attached #3
Since I move dead tractors around from time-to-time, here is what I do:
First, you have to get the FEL bkt off the ground. You will either have to
use a jack under the cross-tube or you can crank the engine with the
starter (assuming that is not your problem) with the FEL valve joystick
pulled back. Next, you will have to secure the loader arms in the UP
position. You can try chaining it up if there is something to chain to, but
be carefull of damaging things. I once had a tractor delivered where they
had strapped the loader a few inches off the ground, but they had crushed
some of the hyd hardlines on the cross tube. What I like to do is make a
couple of "stop blocks" that get pinched betw the FEL boom cyl bodies and
the rod cross tube. I use steel pipes cut in half the long way, but you
could also make something out of wood. You can see these stop blocks
in action (inaction?) at tractor shows and some dealers.
   / Getting tractor to the dealer with front loader attached #4
Jack the loader up while the joystick is in the float position, then make spacer's from angle iron to wrap the piston's on the cylinders to prop the loader up. Just wrap the pistons with rags to protect them. Secure the angle iron on with hose clamps. Also, be sure to do both cylinders.
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
2015 Ford F750 Reel Loader Truck (A52377)
2015 Ford F750...
2015 Ford Econoline Shuttle Bus (A55788)
2015 Ford...
BUSH HOG 297-8' ROTARY MOWER (A51406)
BUSH HOG 297-8'...
1838 (A51248)
1838 (A51248)
