What Size Trailer
/ What Size Trailer #41
Best thing to do is crawl under the truck. If 3.55 or 3.92 is the only available look for something with those numbers in it on the axle. It may say only say 55 or 92 but you will figure it out.
Chris
Or turn the rear wheel one full rotation and see how many rotations the driveshaft turns. :eek:
/ What Size Trailer #42
I pull a 1715 N/H on a 16' Utility trailer with a nisson Hard body with a 2.4 4 cyl , 5 speed trans , 4.10 rear. but the truck is rated at 3/4 ton. Weight of trailer is 1300 LBS , Tractor 3000 With tires loaded and Brush hog attached. that is 4300 LBS . 800 LBS over rating of truck. use equlizer hitch & sway control. have brakes on all 4 wheels of trailer, and that is all the truck wants belive you me. Will pull but you have to keep a fire lit under it .I have pulled tractor for 4 years with this truck tuffest little truck I have ever owned.
/ What Size Trailer #43
Good point. I woke up from my nap thinking the same thing. Just mark the drive shaft with chalk and the tire at the 12 o'clock position and rotate. It will either take 3.5(3.55 gear) turns or 4(3.92 gear) turns with one full revolution of the tire.
Chris
/ What Size Trailer #44
:confused: The specs are on the door plate and/or in the manuals.
1* Seems pretty simple to me.
1*Sure it's simple enough to take a look at the specs on the door plate but what's not so simple is finding a used 1/2 3/4 and 1 ton pickup all at the same time so you can take a look at the 3 door plates to compare the specs between the 3 trucks.
That's no problem going new but used is a whole nother ball game.
/ What Size Trailer #45
OldMax,
I have a Toyota Tacoma Quadcab with a 2.7L automatic with their optional ECT control.It changes the tranny electronically for towing. I pull the same set up,1710 N/H w/FEL. These are tough little trucks. Bought mine 8 years ago and haven't had a moment of trouble.Just regular maintenance. Used to have a 1976 F100, 390 ci, C6 w/low stall converter. Pulled 26' boat back & forth from Central Fla. to the Keys forever. Why I ever got rid of it...I'll never know,but it went to a good home.
/ What Size Trailer
WOW towing all that weight with 4cyl...:eek: guess I will be fine then!
/ What Size Trailer #47
Apparantly we have a failure to comunicate..............over & out:(
/ What Size Trailer #49
oldmx and fltem06 - you both towed big trailers and tractors with a 4 cyl trucks? you got more guts then i ever would and patience too. I don't think Ill ever tow anything that heavy with a 4 banger. I'm using a s-10 blazer with v6 and it barely does the job with no problem with no extra power to spare. Its not like i need to do it fast and hard towing as i probably tow 50 percent of the time with the blazer.
/ What Size Trailer #50
I don't tow anything fast,matter of fact...I do get alot of sign language when towing.;)Very short distance hauling basically is all I do.
ATTENTION PLEASE READ (A60462)
ATTENTION PLEASE...
2010 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2010 DRAGON 150...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
John Deere 7410 (A53317)
John Deere 7410...
Compressor (A55973)
Compressor (A55973)
