Tiller tiller recommendation for a B7510HST
   / tiller recommendation for a B7510HST #1
Dongerosa
wellington ohio
7510 bota...RTV 900
Looking for a tiller for general use. The B7510 has 16 pto hp...looking at CCM CR50 or the MR130, like the fact the MR130 is much heavier...but it requires 15 hp the drive, Both are the same price. Which is the best for my B7510? or other options?
   / tiller recommendation for a B7510HST #2
You can always take the tines off the outside row of tines to reduce HP. requirements.:D
   / tiller recommendation for a B7510HST #3
You want one wide enough to cover your tracks. I'm very happy with my Befco tiller. It's one tough machine. I also have a Befco post hole digger that has worked flawlessly for many many years. I have their slip-clutch model. Here's their tiller page...
BEFCO - Products - Rotary tillers - Till-rite T30
   / tiller recommendation for a B7510HST #4
Not to hi-jack this thread but what model befco post hole digger do you have?I am looking at the model 200 series,48 inch depth and 12 inch auger.Thanks,coobie
   / tiller recommendation for a B7510HST #5
You shouldn't have any problems. I run a 45" Agric behind my 15hp/14pto Mitsubishi. I have run it behind it behind my L2800 also and I had to increase the spring tension on the slip clutch to keep the tiller rotating due to the increse hp.
You also don't have to run full depth on the first pass to get the results you want.
   / tiller recommendation for a B7510HST #6
Mine is an "M2". I think they have renamed the line since I bought mine.
flooring (A55758)
flooring (A55758)
2016 Ford Transit Connect Cargo Van (A56858)
2016 Ford Transit...
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
2016 John Deere 5055E 55HP Utility Tractor (A55973)
2016 John Deere...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
