LA243 FEL Bucket Level Rod Design
   / LA243 FEL Bucket Level Rod Design #1
Usta
Gold Member
Central Vermont
2008 Kubota BX2660
I designed and built my own bucket level rod for my Kubota BX2660 FEL and would like your comments. See attached PDF file. I did a lot of testing and experimenting with this design and thought that others could use my design.
Design Features:
Small and compact design matches proportionally to the rest of the tractor.
Short rod length places the indicator in front of the headlights for night time work, and at a comfortable viewing height.
Indicator window allows for fine tuning of bucket downward angle.
Set screw allows for adjusting indicator for use with other attachments.
I have detailed plans in Autocad format also if anyone is interested.
  • KubotaBucketRod-11x17.pdf
   / LA243 FEL Bucket Level Rod Design #2
Very nice!
I like the ability to quickly adjust for other attachments.
Thanks for taking the time to prepare such a detailed post.
Regards
Sherweld
   / LA243 FEL Bucket Level Rod Design #3
Thanks for the great plans. I've been thinking about a level indicator for my BX2660. This sure will be a bunch easier without the usual trial and error. Keep up the good work.
By the way, how do you like your toothbar?
I just received the Toothbar a few weeks ago, and being in the snow belt, I have not used it yet. I am very impressed with the quality and fit though.
On the Level Indicator, The 3/8" rod fits very snug in the tubing, so I ran the bar across the bench grinder a bit to loosen the fit. The rougher and no longer perfectly round bar should also hold the grease better.
   / LA243 FEL Bucket Level Rod Design #5
Great job and I love the detail from the CAD system. That's a great system isn't it. It (The leveling rod) looks just like the one that came with my 1983 B7100D except it didn't have an adjustment on it. I just took a black Marks-A-Lot and marked the rod for the different angles that I used. Again your drawings are excellent and easy to understand.
The Gotcha Man
(INOPERABLE) MAROOKA (A50854)
(INOPERABLE)...
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
2020 MACK PINNACLE (INOPERABLE) (A50854)
2020 MACK PINNACLE...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
