Minneapolis Moline BF
/ Minneapolis Moline BF #1
flusher
Super Member
Sacramento
Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
Found this nice 1951 MM model BF tractor locally. Four cyl gasser (Hercules 1XB3SL engine), 25 hp at the drawbar.
Straight sheet metal, good rubber.
Wheel weights. The hydraulic ram for the 3pt hitch is visible on the frame in front of the left rear wheel. Red cylinder above the fender is a fire extinguisher.
Swinging drawbar. 3pt looks OK. Need to replace a leaking pto seal. Bought this tractor mainly because I wanted to have a small MM model with bull gearing on the rear axle.
This tractor is actually a B.F. Avery model R. MM bought Avery in 1951 and since MM already had its own model R tractor, the Avery R was renamed the "BF" in honor of Benjamin Franklin Avery, the founder.
Cost: $1300
Plan to make this a parade tractor. But it will earn its keep pulling my recently restored MM P3-6 grain drill to seed the hayfield.
/ Minneapolis Moline BF #2
Flusher, That would be a real find around here in NC. not to many MM here but did have a few Avery 's. Looks to be in exc cond also. I saw one like it for sale at the NC threshers reunion last year not restored, but had been painted guy wanted 6,000.00 for it. It didn't look to be in as good condition as your find. Later, Nat
The MM BF is a fairly rare tractor and is definitely hard to find outside the upper Midwest area. The 1951 BF production run was only 2621 units. The total BF production run from 1950-53 only amounted to 7627 units. My MF135 diesel, by comparison, was produced in the hundreds of thousands.
This one showed up on craigslist last Aug and didn't sell until I showed up last week to eyeball it. It will need work on the engine starter, but otherwise it's in fine shape. I'll tear it down later this year and do a complete restoration.
/ Minneapolis Moline BF #4
Nice find! Glad this one is getting restored.
/ Minneapolis Moline BF #5
Front end and sheet metal look a lot like a WD Allis Chalmbers. We owned a 1956 or 1957 WD-45.
Good looking tractor though. Did the MM have original 3 pt hitch in 1951.
Don
Don
Interesting. As a matter of fact, the Allis Chalmers WD is on my wish list. Almost bought a 1951 WD last year with tricycle wheel layout, but passed on the chance. I prefer the wide front configuration.
It's my understanding that the 3pt was an option that Avery/MM offered. The rocker arm mechanism is essentially a bolt-on/weld-on unit that's not integral with the tractor's rear end configuration.
The hydraulic ram for the 3pt and the hydraulics reservoir are bolted onto the frame also.
My guess is that Avery was prevented from incorporating a Ferguson-type 3pt into their tractors like you see on a Ford 8N, for example, until Harry Ferguson's 3pt hitch patent expired sometime around the late 1940s. Hence, the goofy-looking layout you see on this BF. I suppose some BF afficionados consider this 3pt kludge as a charmingly eccentric feature of these tractors.
/ Minneapolis Moline BF #7
Flusher,
Where do you attach the middle Arm of the 3pt hitch? The picture isn't clear. Do the lower arms swing?
Don
Flusher,
Don
There's a bracket just under the seat for the top link and its retention pin. You can see it in the rear view previously posted in this thread.
The lower arms swing OK. Right now the tractor has rigid sway bars on the lower arms. I'll probably replace them with sway chains and turnbuckles.
/ Minneapolis Moline BF #9
You mean theres another BF out there Thats the first wide front Ive seen. I got the other one thats a norrow front. My neighbor got it about 16 years ago and gardened with it it had been rebuilt but the owner didnt sleeve it and she throws the dip stick out. He gave it to me 2 years ago I had to cut it out of the trumpet vines and drug it home. I need to reman the grill its got a mid mount lift and a funky 3point. Also small Oliver crawlers used the same frame as the power unit in the smaller OC line. And i think some of the General line of tractors.
/ Minneapolis Moline BF #10
From the photo, it doesn't look like the Avery/MM BF 3-point hitch/swinging drawbar. It looks like someone fabricated that one. The hydraulic pump, reservoir, cylinder, and controls look original, but the rest doesn't.
I have my father's Avery R he bought new in 1950 that was converted to a MM/BF with the MM factory upgrade kit that was installed on many dealer inventory Avery R tractors after MM purchased B. F. Avery. My father and I installed the kit on his Avery R in the mid-50s. The 3-point hitch has adjustable lift arms (hand crank to adjust on the right side) and an adjustable lift arm stabilizer bar. It was all bolt-on, no welding required.
Bill
Bill
Interesting. Thanks for the info. I'll have to research this issue more. Don't have any photos showing the Avery/MM BF 3pt and swingbar setup. I'll keep looking.
/ Minneapolis Moline BF #12
When I get some time, I'll take a few photos and post them so you can see what it looks like.
Bill
/ Minneapolis Moline BF #13
I too have a BF MM or Avery R. My grandfather purchased it as a dealer repo in the early 50's. It has the Pesco style hydraulic system (box on right front with push style rod) and narrow front end (two wheels). I also have another one that is a wide front. It has the hydraulic system like the one shown in this thread. I have 1 set of Avery 2 row cultivators, 1 set of MM 2 row cultivators, 2 MM mowing machines, 2 plows, mowing machine owner's manual, cultivator manual, and Avery owner's manual. I still plow with the narrow front tractor and it does a great job. i also use one of the mowing machines to clip under fences. The wide front tractor was bought for parts, but I plan on restoring it also.
I have been researching to find what year my BFs actually are. I noticed on the forums the serial # is stamped into the frame on the right side. When I get the numbers I will post my findings.
Rumor has it, the narrow front end repo tractor was originally red and the dealer painted in prairie gold before my grandfather bought it. I have black and white photos that clearly show it having the BF MM decals.
First question I have is where do you buy reproduction parts. I need to overhaul both tractors. The narrow front runs decent, but smokes a little. The wide front, well lets say it needs a total overhaul. I will be needing things like shifter boots, gauges, throttle cable, gauge cluster plate, and engine rebuild kits.
I will post pictures of them when I get home this weekend. I will start a new forum post to keep from hijacking this one.
Any help you can give is much appreciated.
Hi there. Welcome to TBN.
I'd start by looking at the MM, Avery, Cockshutt forum on
http://antiquetractorsforum.com/
Many of your questions are answered there.
My BF is definitely a 1951 model (serial number is R4230).
The decal on the hood is interesting. It's definitely a hybrid of an MM and Avery design.
The decal contains the name "Avery" which is unusual.
I think this is another indication that this particular tractor is a transition model.
The paint job looks like a mix of Avery red and MM prairie gold. The underside of some of the parts look like the paint there is prairie gold.
I have it pretty well disassembled.
It has the adjustable wide-front axle. One of the sliding sections came apart easily. The other one is rusted tight. Have it soaking in WD-40 now. Took 5 gallons of WD-40 to cover the part in the soaking trough. Fortunately that stuff is reusable.
Hope to pull the engine early next week. Busy with other stuff this week.
/ Minneapolis Moline BF #15
I didn't have any luck finding a number stamped into the frame, nor did I find a serial # plate. All I could find was the engine plate. Any other casting numbers that could determine the year?
Here's the serial # of my BF
You're looking at the top side of the rear end of the right frame channel near where it attaches to the transmission.
And here's the tag on the right side of the Hercules 1XB3SL engine below the removal cover for the push rods
Hope this helps.
/ Minneapolis Moline BF #17
Thanks for the help on locating the serial number. The number was filled in by layers of paint. It is serial #R2424 for the narrow front end one. I have not checked the wide front tractor yet.
One interesting note, my father took my grandfather's tractor and a donor tractor to make one that all the mechanicals were in good shape. In doing that, he used my grandfather's engine and the donor tractors frame, transmission, and rearend. So, the serial #'s are not totally matching. Luckily, we think we still have the old frame rails. Will go looking this weekend to see if they turn up. If we find them, we are going to switch the frame rails. Then, the pesco hydraulic system #s should match with the frame and engine #s. The only thing not original will then be the rearend and transmission. What a mess!
Are you going to paint your 51 prairie gold with MM decals or red with Avery decals? Let me know if you can find a decal that matches the one you currently have using Avery instead of Modern Machinery.
And the big question is....Is a 51 model a BF MM or an Avery R? Since MM bought Avery in 51, then I would assume it could be either, but I would tend to lean toward the MM. Your thoughts???
Good question. Glad you found your s/n. Looks like your BF is an early 1951 unit.
I'm leaning toward MM colors. However, The hood, radiator frame and fenders on my BF are red, not PG. And the wheels are painted red. The only PG color on my BF is on the pto housing
and on the HKG hydraulics unit
I don't see any other indication of PG paint and I've torn the tractor down to the engine, transmission and rear end so far
And there's this funky pale yellow color on the main frame rails and on the engine. Don't know what original color this is supposed to be. Need to do more research on this issue.
/ Minneapolis Moline BF #19
Looks like you are making progress. It's amazing how fast you can tear one down, but going back together is a different story. Could the light yellow paint be a rust inhibitor primer?
I took pictures of mine last night, but did not have time to upload them. They aren't very good, since it was wedged between the hammer mill and the corn picker. I also checked the wide front BF and it's serial # is R5355. Makes it a 52 model.
On the BF Avery website, there is a 51 model R with cultivators for sale. Looks really nice for $2800. His serial number is R2405. Probably made the same day mine was.
I am in desperate need of parts vendors. I am currently restoring my John Deere A, finding parts is not a problem at all. But, the BF is a different beast. Do you know of any other BF MM vendors besides Steiner Tractor Parts? I really have it in for them. Talked to them at the farm machinery show in Louisville, not friendly at all. He gave the guy in front of me a free shipping ticket, but did not offer one to me when I told him what parts I was needing. He just kinda shrugged me off. Since then, I have ordered about $700 worth of parts from other vendors. Guess that is just their loss.
We plan on restoring the 51 model in the fall. We bought new rear rims and rear tires for it the other day. Just buying a few parts here and there for now.
Try Zimmerman and mandmsurplus for engine parts
ZIMMERMAN OLIVER-CLETRAC, Parts Source for Cletrac Crawlers
mandmsurplus.com - Home
Apparently some Avery and Oliver/Cletrac parts are interchangeable.
Also try molineparts for seals
Index - MolineParts.com
I haven't ordered BF parts from any supplier yet. Still tearing down the tractor and don't know what parts I'll need to finish the restoration.
Good luck.
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A60352)
2019 Allmand...
pressure washer, and trailer (A56859)
pressure washer...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
