Large Garage Shop design and cost
   / Large Garage Shop design and cost #11
I think you can get a steel structure building that will freespan that 40 foot width and allow you to arrange the inside as you please. Leave it all open or partition it off. Also they are pre-engineered for wind and snow loading for your area. You can either buy the material and erect it yourself or hire an erector. Just Google Steel Buildings for a company near you that does the pre-engineered buildings.
   / Large Garage Shop design and cost #12
We ordered and put up a 70 by 110 ft clear span steel building for a local town highway dpt.. The previous poster is wrong by stating they are pre engineered for a given area, In our area,, we need 40 lb snow load minimum, however, when one spans wider than 40 ft, in our case (70), the engineering design changes totally again. I believe most steel buildings have a 20 lb snow load however, some states or areas require much more.. We insulated all around the building with 2 inch foam, put two layers of 2" foam in opposite directions on the floor area, and used PEX tubing for heat, and 5" avg of concrete poured. An area 15 ft wide and 50 ft of one wall is offices, two bathrooms and a furnace room. The rest is wide open. It has triple rolled insulation for walls and ceilings, I forget how many mercury vapor lights, electric plugs etc, etc. 3, 14 X 14 and one custom made 14 high by20 wide overhead doors. I was chair of the committee many years ago, and the town finally bonded a loan to start construction,, The difference between original plan was modine heaters overhead, and 5 14 X 14 doors... The biggest change being radiant heat in the floor.. To date,, the jury is out on the 20 X 14 overhead door and even I am surprised at the cheap cost (comparativley speaking) to heat the bldg.. It cost from start to finish, 400,000 complete, There was no change orders in the process. Last year the building used 400 gallons of oil to heat,, Not bad considering 6500 sq ft wide open and 23 ft to the center of roof, and the constant closing and opening of garage doors, trucks- tractos in and out constantly.. It is now in it's fifth winter season..
   / Large Garage Shop design and cost #13
I'd love to see the pictures, but the links don't work.
Sounds like a nice shop.
Well, lets try this again: 002.jpg
   / Large Garage Shop design and cost #14
You didn't mention height for the building. With something that large, either for your as yet undetermined nedds or for resale consider at least 16 ft inside ceiling with at least one 12'W x 14'H entrance door. That way trucks / RV's will fit.
   / Large Garage Shop design and cost #15
The economy of floor heating is hard to beat. We heat about 4000 sqft by a geothermal heat pump and we usually spend less than 100 dollars in December and January for heating. Needles to say that the cheapest heating is good insulation.
   / Large Garage Shop design and cost #16
EddieWalker really nailed this one down. what else can be said.
In 07 I had a 40'x85' on a pad built right at $17,000. I would have built it for myself but we where in a large corn harvest and I needed the building for hay so I had to contract it out.
I think you might look at a 80' over a 60' with all you plan to put in it. I have a 60' on concrete as well and I tell you getting 2 pickups and a tractor in it and room to work is a chore. Dont get me wrong the 3 fit in it just fine but then comes the work bench and everything else. Including riding mowers and kids 4 wheelers. You get the idea. 60' just really is'nt much space.
I know. For that cost its a no brainer. I just may go with 80'. I think concrete pads are looking at $12K for the 40x60. I had a metal framed building estimated for $52K. Looked at a 5 bay 34x72 stick built with a center loft. The builder said his customer had about $110K into it. He said maybe about $82K without the finishing touches inside. If I can't find something significantly better priced than that, I'll just barf!
I know that a pole barn construction may be the least expensive, but I am leaning away from that. So, aside from that, what would be the most practical style? Metal frame, stick frame and metal siding, all wood, straight rectangle style, barn style with a center loft, etc?
   / Large Garage Shop design and cost #19
Contrary to what LarryB stated, when you order a steel building, they are designed by a given area. You have to give the state and county where the building is to reside, then the design is verified that it conforms to the local county and state Building Codes minimum FOR THAT AREA. That is part of the pre-engineered part that you get when you buy the building. You can elect to go above the minimums for wind and snow loading if you want to pay the extra money, at least on the company I was dealing with you could. Snow loading isnt a big concern where I live but hurricanes have been know to come through frequently. The minimum wind loading in my area is 90MPH but they would certify the design for 120 if you wanted to spent the extra money. I really didnt check the snow load very close since we only have snow about once ever 20 years and then only 4-6 inches at most. but I believe it was 20lb sq foot. You can find all kinds of steel building manufacturers on internet and they will provide you a quote very quickly. Some have online quotes for standard sizes and designs that you pick and choose everything and it immediately gives you the price including shipping. Others I queried would email you back within a day or so with the quote. There is some limits like the sizing, it has to be in certain increments for length and width which I believe was 5 foot in width and 10 in length, You couldnt specify a 62 x 44 or some such size. When you do that you get into the custom design that will cost you lots of extras for the design, plus the custom material cost.
John Deere GP Tractor (A50514)
John Deere GP...
2005-  3412 ENGINE (A50854)
2005- 3412 ENGINE...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
