BX24 and BX2350 RPM differences
   / BX24 and BX2350 RPM differences #1
FishAlaska
I have a 24 and my dad has the 2350....they appear to be the same machine other than the backhoe on mine and I have a L240 loader and he has the L243 loader....I dont see a difference in the loaders.
My ? is...his max RPM is around 3900 and mine is 3500. What would be the 400 RPM difference...we bought these new.
   / BX24 and BX2350 RPM differences #3
The rated RPM for both machines is 3200 RPM. PTO speeds are set at 3200 to. Your governor must not be adjusted right. I would not want to run one at 3500 or 3900.
   / BX24 and BX2350 RPM differences #4
The BX 24 and BX 2350 is the same tractor except for the BH.
Same goes for the BX2230 and the BX23.
   / BX24 and BX2350 RPM differences #6
I have a 2350 and it is rated at 3200. Mine will run at 3400 though. I dial it back unless I am mowing, then I rev it up. 3900 sounds way to fast.
I think 3900 is too high.....no wonder his tractor felt so much faster when traveling. We need to get his set correctly....mine fluctuates 3450-3500.
   / BX24 and BX2350 RPM differences #8
My BX2350 will max out at about 3200, give or take 30. I think 3900 is way too fast. This is the first Japanese diesel I have owned and 3200 sounded really fast to me until I got used to it, but they are designed to operate at 3200.
   / BX24 and BX2350 RPM differences #9
When I had a 24 my dealer told me these machines (24 and older models) never had tach's so don't worry about the RPM's. He said to run it at full throttle if I needed the power. From what he says the engines are built for rental equipment and are meant to be used and abused! I'm not sure I believe him, but then again I never threw a rod through my hood. I'm not sure there is a difference except now maybe the tach is made/ hooked up different?
International Harvester Farmall FC (A50514)
International...
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A50323)
2019 Kenworth T880...
5' X 20' 3/8" THICK STEEL PLATE (3) PIECES (A51244)
5' X 20' 3/8"...
2005 Wilson Hopper Bottom Trailer (A50514)
2005 Wilson Hopper...
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
