3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,931
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
My stock oil sensor went out when I broke off one of the electric connecting posts.
This happened when I was re-assembling the tractor after splitting it. I went to Napa and bought a mechanical oil gauge and finally installed it the other day.
I installed a "T" into the oil sensing port and put the stock sensor in one outlet. Then I used some 1/4 pipe extensions and a cut-off hydraulic hose to run up over the fuel tank (under the body) and over to the dash board. Drilled a couple holes for the mounting screws and hose and then plumbed it up.
I was also able to fix the stock sensor, so now I have 2 oil gauges. The stock gauge reads in MPa and the Napa gauge reads in PSI. Notice they are not exactly the same but close enough for me. I know with the mechanical gauge I still at least have oil pressure.
Rob-
Rob-
