Best block heater for a 7520?
/ Best block heater for a 7520? #1
QRTRHRS
Elite Member
The Bluegrass State
None at this time.
What with this cold weather setting in lately, I need to get a block heater on my tractor. A few weeks ago, I spent a couple of minutes looking for a freeze out plug to install one. I only saw one that seemed easily accessable on the left side of the engine. Did I miss one?
Or would an inline hose unit work better?
Now that the mud has firmed up, I have to get out to do some work but I hate starting up the tractor and hearing all of that clanking.
/ Best block heater for a 7520? #2
I don't have a 7520 but a 2615. The inline lower hose heater works great for me and only took about a half hour to install. I get home from work normally about 3PM and have the heater plugged into a timer that comes on at 1PM so when I get home the coolant in the block and radiator is about 140 degrees. That helps make for an easy start.
/ Best block heater for a 7520? #3
I second Georges opinion, although I've never tried anything else, I put in the same heater on the same tractor as he did, and nothing could have been easier. It works great, makes it seem like a July start !
/ Best block heater for a 7520? #5
There is a pipe plug right above the starter motor. A Tisco number GE360 block heater kit fits it. I keep them in stock if you need one.
Sorry not to get back to my thread. Started a new job, 7pm-730am, two on, two off, etc, etc, so I have not had much time lately.
It so happens that I have a lower radiator hose drip that tightening has not stopped. I have to measure the diameter and pick up one of those wider band type of clamps that equalize the pressure better than a screw clamp so I might have to pull the hose anyway.
On the other hand, I always used the freeze out plug type before. Thanks for the info LAWALLSTRACTOR, I will let you know if I go that route. Does the Tisco heater screw in or is it a compression type?
/ Best block heater for a 7520? #7
The Tisco heater screws in.
RoadTec RP190 (A61307)
207282 (A52708)
207282 (A52708)
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2018 CATERPILLAR 262D SKID STEER (A62129)
2018 CATERPILLAR...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
