Experience with fuso 4x4
/ Experience with fuso 4x4 #1
WantedWolf
Gold Member
South Alberta
ditch witch 6510
Im looking at an FG140 model has anyone had experience with them.
Its a medium duty cab over made by mitsubishi fuso its 4cyl turbo diesel putting out 155 hp @ 2700 rpm and 347 lb.-ft. @ 1600 rpm, it has a GVW of 14050# but Im concerned that the engine will slug on hills and with heavy loads.
As a cab and chassis they are priced about the same as a new big3 3500,
/ Experience with fuso 4x4 #2
My question would be do you need this truck? Also what will it do that a 1Ton Diesel will not do? I have zero experiecne with any type of truck other than pickups so I am the wrong guy to ask but my fear would be the cost of repairs. Granted they run forever but when these types of trucks need service, even simple things like brakes, it can be expensive.
Chris
Chris
very good point on the repairs. I am considering that and the distance to the dealer is substantial . I am writing a list of parts like glow plugs, oil filters, brake pads, etc. to find out prices before hand on things I expect to go first.,
The GVW is higher on the fuso then a 3500p/u but the overall power is lower
So I can legally to more but I likely cant physically. Fuel economy will be great but top speed is 68mph/110km.
If say the starter last 3 times longer then the dodge then I wouldnt complain about paying 3 times more for the part and only servicing once, if thats the case great.
/ Experience with fuso 4x4 #4
I do not have any experience with the fuso, but I used to use a couple of isuzu units. They were setup box truck style, they had 23,999 total weight rating (i believe, but it has been about 10 years so it it hard to remember). They were very reliable, even more reliable they the fleet of Ford e250's and 350's that the company also had. I do not know if they were super expensive to have serviced, since I was always traveling and we always tried to service the vehicles at our home office, but none of them ever broke down on me.
Dave
/ Experience with fuso 4x4 #5
I heard the Mitsus have the longest warranty in the medium truck business. Something crazy, like 200,000 miles. So if you're buying new, I wouldn't worry about repairs too much.
I think they're an excellent choice if LOW OVERHEAD is your biggest priority. If driving a powerful more stylish truck is more of a priority, then go big-3.
The reason they're so reliable is their low power. The driver can't really damage the driveline so clutches, trannies, rears, tires, axles, brakes, etc. all last a long time.
How much heavy towing do you do? Do you live in a real hilly area? I would think if you're mostly running flatland and not pulling over 12K, you should be fine.
/ Experience with fuso 4x4 #6
WW,
Did research on these rigs 5 years ago and every FUSO (2wd and 4x4) I saw at gas stations or loading docks I stopped and asked the drivers how they liked them. Most said they were tough little trucks but slow and very rough riding in the short wheel base (I think 109? I was going to get one used for a hunting rig. Was also going for the 田ool factor? seen some on the web with larger tires, camo paint, lights, winch, flat bed? and really liked them. Not being able to load 6 people into the cab like one of the big 3 trucks was a big factor in my purchase, Hard to find them used with AC was also a factor.
One guy I talked with was driving a FUSO FG (4x4) with a Refer box on back said the thing was murder to drive unloaded. Most 1 ton big 3 truck ride pretty nice now loaded or not
Deaf
thanks guys.
im working at it but cant determine exactly what I will be carrying. I want to be versitile. i wont be in a hilly area when all is done but i am for another 4 months min.
they do offer a pretty amazing warrenty `175000k/5year limited on everything
4year rust warrenty included.
iv heard its bouncy, and slow between 90-110km 110 being top speed
after warrenty theres fun things like propane injection and roll cages etc but for now a simple toolbox extra fuel tank and GN hitch is all i Would add.
most people do make expo rigs from them but one guy farms in texas with an FG. Many tow backhoes and skid steers.
I havent decided yet. I will test drive 08/09 Dodge/chev/ford beggining next week
thank you for the replys:)
/ Experience with fuso 4x4 #8
GM makes the same basic thing (I think they call it a W series, usually Isuzu motors)), any GMC truck dealer should be able to point you in the right direction. That might solve your dealer being far away problem.
I see you are in Canada, and I know your laws are different, so.....
But here in the states, if the GVW is 14,050, you can only put a 11,950 GVW trailer behind it or you are over 26k and you need a class A license to drive it.
You could put a 10,000lb trailer behind it and be ok, but what's the point of that?
Most 3500 series pickups rate at 9900GVW so you can run a 16,000lb trailer behind them. (less some axle weight issues) without needing the Class A license.
Something to think about
the turning radius is amazing on those cab overs, incredibly short wheelbase.
/ Experience with fuso 4x4 #9
This CDL thing is argued more than Ford/Chevy but if its for personal use he can be over 26,000# without a CDL. Also check the data. Most 1 tons are now way over 9,990 gvwr, that's 3/4 ton territory. My 2006 F-350 4x4 SRW is 11,500# and if it were a dually it would be 13,000#
Chris
/ Experience with fuso 4x4 #10
This CDL thing is argued more than Ford/Chevy but if its for personal use he can be over 26,000# without a CDL. Also check the data. Most 1 tons are now way over 9,990 gvwr, that's 3/4 ton territory. My 2006 F-350 4x4 SRW is 11,500# and if it were a dually it would be 13,000#Chris
Current 3500 GMC/Chev SRW are still 9900#. I think they keep it like that for a reason(s), eg. keeping combo under 26K, laws in CA and NY, interstate hauling, etc.
Thanks guys.
No concerns there unless perhaps I make a trip through the states. Even then I think My Canadian CDL (class 1) Is still good.
I was trying with everything possible to avoid the American trucks. (no offense to American People.) They are just junk these days.
If anyone local has a 91-93 ram diesel Ill pay top dollar for top quality.
/ Experience with fuso 4x4 #12
Chris
Reading is fundamental
I didn't say CDL
I said Class A
And that is required, personal or not.
And he's going to be hard pressed to convince the nice DOT officer that his cabover 14,000GVW hauling a trailer is not commercial.
Are you sure on the Ford's. What does the little tag inside the door read?
My 02 F250 was like 9200, just like all of them. They'll haul way more, but they "rate" at 9900 for exactly this reason. (and some states ANY GVW over 10k is a commercial and you need a CDL, I believe MIchigan is one). Dodge is the same way i know for a fact.
/ Experience with fuso 4x4 #14
Thanks guys.
Just curious, what do you perceive as "junk" on today's American trucks? I think they're better than ever, albeit a bit more complex.
Hi Builder.
They just dont makem like they used to is my opinion. I would define new as after 1995 range. this is in big part my opinion based on complexity and insuitability of the newer vehicals to be serviced by an average DIY type owner. And based on the newer domestic vehicals I have encountered.
To the defense of all car companys many of these issues were brought on by emmisions and saftey legislation out of there control.
I am very biased to toyota. but they dont cater to heavy towing apps.
Ive easily put more miles on all my imports then my domestics and all imports save one cost less to buy and maintain.
Ive heard so many but this is freshest in mind from another mboard.
"07 ram 3500 48,000 km and the DPF problems, stuck injectors, leaking axle seals, slipping clutch, unexplained stalling, and less than stellar fuel consumption have left a sour taste in my mouth."
You have to sell all these big 3 before they hit 100k and bite you tounge about something to whoever buys it to get a reasonable return. the import cab overs although I now realize are sort of a different class seem to hold there value way longer.
I have few options if I want to tow, and have now available loyalties so ill just take the cheapest to repair, value maintaining medium and sell it as soon as I can find time to rebuild a 91 ram.
I guess its a time issue too, i buy alot less trucks then say utility companys or concrete companys. they want there trucks fixed now to get back to work fast and lose more in lost time then it takes to pay a dealer to fix it.
Id rather take the time to rebuild a caliper or hub at an 8th the cost of quickly replacing an assembly. Just my opinion. theres lemons and success stories even with new trucks i guess
/ Experience with fuso 4x4 #16
Beg to differ on the initial quality of the new Chevy at least. My 08 had no flaws when new and 8 mo. later no flaws. 99 was almost as good. I don't favor some of the designs (hood too high to see over, rains in when you open the door, etc.) but the build quality seems just fine. my opinion.
Jim
/ Experience with fuso 4x4 #17
Hi Builder.
I totally sympathize with everything you're saying, BUT, you have to be careful what you read on the internet. I firmly believe over 1/2 what I read is less than truthful when it comes to complaints about products. Many out there have one problem and blow it way out of proportion to get attention or be spitefull towards one brand or another.
If I had a limited budget, big power wasn't necessary and wanted the best warranty I might go Fuso or Isuzu, too.
Jim
Hi jimmy
Glad your trucks been good to you. please be more specific on model and "trim" of your 08. ' The work 06 Duramax is great for power, im unsure of the auto but allisons always been good. just broke the little plastic shift cable coller due to built up snow and ice limiting the travel. and have repaired a blown steering hose. its a SRW and just destroys my ram DRW in the snow but cant keep up with the 4runner lol.
I have a date with the Ford dealer on tuesday but have more interest in a chev/gm. :mad:Fords the only local dealer willing to let me test a new model with my trailer (empty O.C.) . Chev said we dont put hitches in our trucks until they sell them. And then they probably tell you what brand/type to install.
/ Experience with fuso 4x4 #19
Hi jimmy
Just to throw another log on the fire here-my '07 GMC 3500 DMAX/Ally has been near flawless, too.
/ Experience with fuso 4x4 #20
My 04 and 06 Ford Diesels have not been in the shop one day other than the 06 getting a dash cluster replace due to errors in the fuel gauge. Took 5 minutes to change in the parking lot.
Chris
