JD 2520, I added a foot throttle
   / JD 2520, I added a foot throttle #1
jimgerken
Minnesota
John Deere 3720
I found that quite often when snowblowing I wanted to increase engine speed to max for the deep snow parts, but otherwise wanted it running at 3/4 throttle for lower noise and wear. My right hand is already quite busy with hydraulic levers for lift and rotating the blower chute rotation. So I added a foot throttle built from motorcycle parts. Yanmar was kind enough to include provisions for a second cable operator on the injector pump and cable housing fixed bracket, so I added a clutch cable from a Honda CR 250, with a specially-turned brass fitting that allows slide-thru, silver-soldered onto the cable. Since the original tractor cable already slid thru too, this makes the two throttles somewhat independent, but either will override the other to increase the speed. Then I used a cut-down clutch lever and mounting perch, and made a bracket to sandwich onto the footrest area of the tractor. Here are the pics, I think it will make sense if you look at them...
In use, I set the hand throttle to 1900 rpm, and do most of the snow work and transport, but when I approach that big drift or re-plow area down by the street, I step on the throttle and increase engine rpms to the new desired speed. After I get thru the deep stuff, I let up on the foot throttle and it returns to 1900 again.
   / JD 2520, I added a foot throttle #2
Excellent Job! I like the way you fabbed that all up to look like factory.
My Massey 1532 has a factory foot pedal and I am continuously having problems with it freezing. Even my hand throttle freezes when I am out working! I haven't figured out a way to keep them from freezing yet. My tractor sits in my shop which is heated only when I start a fire so I think it must be condensation in the cables.
   / JD 2520, I added a foot throttle #3
Nice job Jim.
Shows how much I know, I would of thought it came with one.
Don't most tractors ?
   / JD 2520, I added a foot throttle #4
Nice job Jim.
if your driving a HST tractor no.
   / JD 2520, I added a foot throttle #5
That is really nice Jim, When is the kit going to be for sale:D
   / JD 2520, I added a foot throttle #6
SWEET, you even have an aftermarket anodized aluminum quick adjust on the perch.......I don't even have one on my bike, much less my tractor!
2006 Toyota 7FGU60 11,250lb Propane Forklift (A55973)
2006 Toyota 7FGU60...
2018 NISSAN Sentra (A56859)
2018 NISSAN Sentra...
2005 John Deere 330CL (A55272)
2005 John Deere...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
Deere 325G (A57148)
Deere 325G (A57148)
