Chains chains
   / chains #1
meanstreak
holland ny
tc 45d
Since i removed the front tire chains its been rough trying to plow, so i bought a set of 2 link v bar tire chains for my tc45d [$ouch] The gentleman that i talked to at tirechain.com said keep them tight and i should be all right, we shall see. I will let everyone know if they workout. thanks again for everyones advice.
kind regards
Blake
   / chains #2
kind regards
Blake
I assume that you put the V bar chains on the rear. I had run chains on the rear of my IH424 when using it on the hills and it did so well I didnt remove them for 6 years when I traded in the tractor for a 4WD. I run them tight and they were similar to the type that are on log skidders just not as HD.
   / chains
yes i will be putting them on the rear after making the mistake of having ladder chains on the front which did damage to the front differential. chains only on front of a 4 wheel drive tc45d is a huge no no.
2021 Kubota SVL 97-2 (A53317)
2021 Kubota SVL...
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A55315)
2018 Cadillac...
2013 Ford Escape SUV (A55853)
2013 Ford Escape...
2019 Ford Escape S SUV (A55853)
2019 Ford Escape S...
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
