Anyone have Gator CX knowledge/
/ Anyone have Gator CX knowledge/ #1
SUPERNUG
MID MICHIGAN
BX22
Thinking about a gator cx to replace my electric golf cart. Thought about a Kubota RTV500 or small mule but can't really justify the extra dollars. Anyone have thoughts, info, or experience with those small gators?
/ Anyone have Gator CX knowledge/ #2
I may be biased because I sell them. They are a tough little machine. I don't know much about the RTV but I do know the CX is a good little gator. In our training in florida they put a sled behind it and 400 lbs in the box and pulled it with no problem. They hooked the same sled up a rtv 900 and it couldn't pull it until they shifted into low range. So it does have alittle pull power. Good luck
/ Anyone have Gator CX knowledge/ #3
I have had four Gator's and currently own the XUV. The first gator I owned was the CX which I purchased as soon as it came out. I believe, it was in December of 2003 when I was reading through some farm magazines that I saw the new "baby gator" listed in the new equipment section. I drove to my local John Deere dealer that afternoon to check it out and brought it home in the back of my pickup. That day was the first I ever heard of the new small gator's. I think I paid about $4500 for it.
The CX was a great little machine as long as you keep it close to the yard or flat, relatively smooth terrain. I used it for yard work and going down the quarter mile to my mom and dad's place where I kept my farm equipment. It started great, steered better, had a very light footprint, was comfortable to sit in, quiet, and had plenty of power for its size. It was excellent for yard clean up and for various chores like pulling a leaf rake. It was small and had the mobility and turning radius to get in tight places. It has the differential lock and did pretty good on the traction department going through light snow, soft dirt or mud. However, I wouldn't want to take it out in heavy mud after the spring thaw.
I would have kept it but it didn't meet all my needs living on a farm. It was fine for the field road but not good to take through the fields. The tires were great for lawns but not tough enough for bean stubble, corn stalks or driving through a thorn patch. The early CX also did not have a rear suspension and a smooth ride depended on the low pressure tires. It did have plenty of power. I had a 20 foot combine head on a carrier that it pulled, I'm sure the weight was near 2000 lbs.
I had the CX for a little over a year with absolutely no problems. I traded it in for a new HPX getting just a few hundred dollars less than what I paid for it new on a trade-in credit. The only reason I did not keep the CX was because I needed something more rugged to take in the fields. The CX was also limited to 15 mph. I traded the CX in on a HPX then traded that HPX in on a second one a year later when they made some improvements. I then traded that second HPX in on a new XUV when they came out.
Would I recommend the CX?, absolutely, but only if you are looking to keep it close to the lawn or somewhat smooth terrain. I actually wish I could have kept the CX and have the XUV too because the CX is superior for taking on the lawn jobs because it is so turf friendly and easy to maneuver.
How about hill climbing? My new house is on a hill. need to go up an incline to get from the front to the back etc. Don't think my electric golf cart will get it done. Will the cx climb a hill with no low range?
/ Anyone have Gator CX knowledge/ #5
I have the RTV500...It does fine on hills as long as you're not looking for alot of speed. In fact I climbed my sandmound with it...probably 45 degrees with no problem. You do have to let up on the pedal for downshifting, just the way it is.
/ Anyone have Gator CX knowledge/ #6
I was hoping someone with more specific CX knowledge would answer, but...
I don't think lack of a low range is an issue. I believe the CX is always in low range- it lacks a "high range" if limited to about 15 mph. IIRC, top speed in low range on the HPX is 12.
I would bet you can get a JD dealer to let you try one out on your property before you buy.
/ Anyone have Gator CX knowledge/ #7
i have john deere gator cs wich is bascily the same it is a vary good utv so far i have added a winch a homemade snow plow and a homemade loader it has 800hr on it and still runs like new
/ Anyone have Gator CX knowledge/ #8
what does this loader look like?......pic's please?
/ Anyone have Gator CX knowledge/ #9
here are some pictures of my homemade loader for you guys
/ Anyone have Gator CX knowledge/ #10
Surprised this didn't get more traction. I have a CX and was looking for snow plow info. I would expect the CX to handle 6" or less with efficiency. 12" would be a challenge....or not. I suppose a lot has to do with where you are pushing it. This has good power, but keeping the rear wheels from spinning would be the concern even with chains and weight. I don't think the snow will stop as much as spinning tires. I am a contractor and have a job in my neighborhood. I have been using the CX and a dump cart to shuttle my tools back and forth. The trailer has an easy 400lbs and I have another 200lbs or more in the bed of the gator. It chugs right up a long steep driveway then up a dirt hill on the side of the house so I can get to the back yard and park.
/ Anyone have Gator CX knowledge/ #11
Right now is a good time to check dealers for Demo unit's, i recently purchased a 550 XUV cheaper than the HX i was looking at, while the bed was smaller, it had more features.
Ronnie
/ Anyone have Gator CX knowledge/ #12
I purchases a CX in 2003 and still run it. It has 2500 hours and is still in pretty good shape. Been through a set of tires and the plastic fenders and dashboard have cracks that I have mended with zip ties (like stitches). The cracks are from vibration and probably just age. The Kawasaki engine takes some time to warm up, but once warm it runs well. Had to replace the drive clutch. It is a fine machine. I also own a Kubota X900 and love the VST transmission vs. the belt drive transmission of the CX.
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2013 MACK CHU613 WINCH TRUCK (A67714)
2013 MACK CHU613...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer w/ 7 Ton Gooseneck Trailer (A66734)
2023 JCB 3TS8T...
2015 Ford F-250 Ext. Cab Animal Control Service Truck (A66736)
2015 Ford F-250...
1999 INTERNATIONAL 4900 (A67714)
1999 INTERNATIONAL...
2014 JOHN DEERE 700K LGP CRAWLER DOZER (A65056)
2014 JOHN DEERE...
