BX24 hour meter problem
   / BX24 hour meter problem #1
coreshot
Gold Member
Utah
Kubota BX24
I've searched, but didn't really find anyone with my exact problem. I've talked with the dealer, and it sounds pretty common.
My problem-When it's cool outside, not necessarily cold, my tach/hour meter blacks out to a point that you cannot see the digits. It looks like someone took a black Sharpie to the inside of the glass. Once it warms up outside, the black dissappears and it works just fine. The outside temp. has to warm up, not the tractor. If it stays cold out, the tach never clears up.
I've talked with the dealer, and they basically said that if it works sometimes, then they won't do anything about it. If it stops working completely, they'll replace it. This seems like bs to me, as we are in the middle of winter and I have no way of knowing where my hours are. I'm getting close to the 150hr. service, but don't know how close. I also have no idea of hours to charge for seat time with my landscaping. Any thoughts?
   / BX24 hour meter problem #2
Suggestion, contact Kubota directly and share your story and ask them if the way the dealer is handling (or not in this instance) the issue is their standard policy...If it gets back to the dealer from higher ups it may tend to tick them off so weigh that as well as far as possible future work done by them...Good luck.
Don
   / BX24 hour meter problem #3
hmm, I'll have to look at mine today. we just got our first cold snap near 0 today. However i can relate to you though, I have seen where it wass a bit hard to read but still readable in cold weather, then when it warms up from the engine heat, I can read more clearly. I wasn't bothered by this since I was a computer tech and it shows the exact same signs as the LCD's in laptops displays. If left in the cold, the liquid can expand and makes it hard to read until it warms up. It can also cracks the display to point where its unreadable. I just dont think this will happen on the bx24, ( i hope not) as the lcd is much smaller and less likely to crack and exapand as much. (fyi- i am assuming the last part)
   / BX24 hour meter problem #4
Kubota should have put analog tach and hour meters in the BX's in the first place. It would be a lot better and wouldn't have problems like this.
   / BX24 hour meter problem #5
Turn your lights on for a while, the back light will warm up the LCD fluid for a display, maybe just enough to read it. I have the same problems
I've tried that, with the cold we've been having, it doesn't make a difference. Probaly would in cool weather though. How about a 12v heater (light bulb, etc.) behind the unit to warm it up a bit more? Any ideas?
   / BX24 hour meter problem #7
Its not that cold here yet, i can just make out the top half of the numbers still. Last option maybe get a heated storage area :)
I do have a HF 12v heater fan thing that someone gave me, I will try plugging that in and pointing it at the hour meter and i will let you know
   / BX24 hour meter problem #8
My BX24 did the same thing and it got worse. I had 2 hours shy of 300 hours on it and was still in warranty. My dealer changed it out under warranty and I even bought the tractor used from a private seller. Before I replaced it, I would take a 300 watt work light and hang off the steering wheel for about 10 minutes after a couple of uses so I could keep track of the time. After doing that, the display was crystal clear!! I waited till I did the 300 hour service so that I knew where I left off. Now my tractor only has 38.5 hours!!! When you use a bright light like I did you just have to be carefull not to let it get too close so it does not melt anything. I would call Corporate and explain the problem. That is what I was told to do if I did not get satisfaction from the dealer. Luckily, I did not need to call corporate.
Deano
   / BX24 hour meter problem #9
The hour meter was analog in the previous generation...I much prefer it that way.
I think "customer opinion polls" told them there was a deep desire for a tach on these machines and the cheapest way to accomplish that was a combo hour-meter/tach thingy.
Don't see much of a need for an RPM gauge on these things. I don't have one and don't really care what the RPM is...it is either idling, WOT, or something in the middle depending on "feel". It being 2,700 RPM vs 2,500 or 2,900 wouldn't make a hill of beans difference to me.
Mechanical hour-meter is probably cheaper anyway, especially before all the warranty replacements Kubota has been on the hook for.
   / BX24 hour meter problem #10
this morning , the hour meter was readable this morning in 6 degrees weather, but it was faint. possible issue in the future ? only time will tell.
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2011 INTERNATIONAL PROSTAR PREMIUM DAY CAB ROAD TR (A51243)
2011 INTERNATIONAL...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52128)
Marliss Industries...
