In the tire sealant
   / In the tire sealant #13
Slime and its ilk are a great aid in keeping tires from going flat on the bottom. I have never experienced them to be a permanent trouble free fix tho. The failure mechanisms seem to be; 1)degradation of the particulate/fibrous matter relied on to form the filter cake, and 2)gravity induced flow of the slurry off a leak during long parking periods. I find it usually works trouble free for a couple hundred hours before becoming touchy about orientation and duration of parking. Even then pumping it up lets you use it leak free as long as you move around to redistribute the fluid. Adding more rejuvenates it briefly. Ive had it flat out fail on wheelbarrow rim leaks.
Larry
   / In the tire sealant #14
Yep, I've been running it for 2+ years and haven't had a flat, working in the woods, since... that's after having 3 flats in a 2-week period before I'd sealed them.
KentT, what is the dosage Hydro Seal per gallon of fill used with water? The website doesnt give numbers.
Thanks, larry
   / In the tire sealant #15
Thats just why I come here to TBN. Someone always knows something I don't and I can always learn something. Never thought there would be a product that could be used for a tire sealant with liquid ballast tires.
Sincerely, Dirt
   / In the tire sealant #17
   / In the tire sealant #18
Sincerely, Dirt
I called the people at multiseal /hydraseal, and his comment was that the product is concentrated , and when mixed, it will be in the right formula. The charts do not show all tractor sizes, and suggested that anyone interested to call customer service., and they will compute the correct amount.
   / In the tire sealant #19
For what it is worth, remember there are two types of Slime, one for tubeless and one for tubed tires.
Edit: Or anyway there used to be; i see on ebay one advertised for both: Item 250353556228
Mike
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2015 Ford Focus (A51694)
2015 Ford Focus...
2025 CATERPILLAR 275 SKID STEER (A52705)
2025 CATERPILLAR...
2021 Ram ProMaster City Van (A55788)
2021 Ram ProMaster...
Schumacher Jump Box (A54865)
Schumacher Jump...
