Pressure washer question
/ Pressure washer question #1
WBWI
Gold Member
SE Wisconsin
Kubota L3130
Can a residential quality pressure washer run off of a holding tank full of water instead of a hose hooked to a pressurized water supply? I don't know if the head pressure of the water in the tank would be sufficient to supply the washer.
I can get electric to the washer with extension cords unless the voltage drop is too great. I could always run it off of a portable generator. Getting water to it is the bigger problem.
/ Pressure washer question #2
A few years back when I think I remember seeing a Kartcher (sp) electrical, residential unit that was capable of pulling water from holding tank.. I have no idea where I saw it or what model it was though..
sorry
Brian
/ Pressure washer question #3
It's been a long time since I read the manual that came with my Northstar washer, but I'm pretty sure it said it needed a pressure supply. That said, I don't know why it wouldn't work of off a gravity flow tank, provided you made sure that all the air was purged from the supply line prior to staring the engine.
You would have to squeeze the trigger on the wand and wait patiently for a continuous water stream to come out of the nozzle. It would probably take several minutes to clear all the air out of the line. If you screwed up and started the engine too soon, you could easily damage the pump. I think that is why they have the warning requiring a pressure supply.
/ Pressure washer question #4
sorry
Brian
/ Pressure washer question #5
I have a commercial pressure washer with a small 30-gal tank. That washer works far better with a pressurized supply than with the gravity fed tank. I think that will be true of all washers.
/ Pressure washer question #6
I did some hoses for a customer that has a 500 gallon tank and a gas powered pressure washer in the back of a box truck. It works real good for him.
/ Pressure washer question #7
Pretty common to run them at the motorcycle events off a 55 gallon drum on the front of a trailer, also mobile wash places often do this type setup as well.
While it may not be quite as good as a pressurized supply, I think you would find it adequete for most needs.
/ Pressure washer question #8
Systems I built for years, you need to have supply pressure 40 - 60 psi to have a working 2500 psi unit with 1 hp 110 volt on clean 20 amp line.
For long runs of electric, just use romex 10g right out of the box with ends applied. Pressure washer will think it's in the garage.
Or 5hp Gas.
You only need a small boost pump from tank to machine when output at gun is 2.5 - 5.0 gallons per minute.
You could use the old shallow well pump just laying around placed into 55g barrel. Aim a torpedo at it and you have warm water.
3 piston ceramic types are the best by CAT. They will go twenty years easy.
Filter it, and it's flawless.
Hot is not recommended for pressure washer pumps.
Hot or super heated is applied after the pump.
/ Pressure washer question #9
I do this when I use My hot water washer in the feild., I have a 330 gallon tank and the spout at the bottom. when o nthe truck the tank ie lower than the pum by 2 feet. It takes a second to prime then it goes on. Ive also gotten to where I Have a sealable vent in top of the tank I tapped it to add a valave and fitting to give it about 10 psi with the trucks air compressor. That helps alot,. I had a 100 dollar waterpump a shurflo that ran off the washers batery but the pressure cutoof quit on me big time and busted the housing. The air works good but with a full tank it usually primes right up. If I cant use my big tiank I have a longer hose and I put the washer on a trailer and leave the tank in the bed up hill. The best thing to do first is to get a 1 inch hydrauilc hose made to keep it from starving. Thats what I did with mine.
/ Pressure washer question #10
If your pressure washer can put out 4 GPM, then it should be able to draw that same amount. The input hose should be a non-collapsible hose like a hydraulic hose. I have seen it suck a regular hose from being round to flat. A trailer mounted pressure pump should be able to draw out of the tank. A little air pressure is good as someone mentioned.
/ Pressure washer question #11
I have a Bosch electric sprayer. It seems to need mains pressure or good pump pressure from the bore. I used it once connected to an old bore pump that had plenty of flow volume but relatively poor pressure. The Bosch kept cutting out. It seems to need a certain input pressure to trigger an internal safety switch. I guess they are all a bit different. Some would no doubt be designed to draw water from an external holding tank with no problems. A possible clue would be the size of the hose input connector. If its just an ordinary 1/2" garden hose connector then it may have trouble if its only being gravity fed. And it would of course depend how high the feeder tank is.
2023 John Deere 6R 145 Tractor (A63109)
2023 John Deere 6R...
Quick Attach Pallet Fork (A62180)
Quick Attach...
(INOP) CATERPILLAR 518 LOG SKIDDER (A63745)
(INOP) CATERPILLAR...
SDlanch SDLGC80 Electric Golf Cart (A62183)
SDlanch SDLGC80...
2026 Kearney 7' x14' (A62180)
2026 Kearney 7'...
2017 International HX620 Quint Dump (A62613)
2017 International...
