Bucket mod - hitch receivers vs hooks
/ Bucket mod - hitch receivers vs hooks #2
Great, thanks.
If the stores were open today I'd be on it right now. I'm going to put 1 in the center of the bucket and see if that is enough before I spend any more to put any on either side.
Jim
/ Bucket mod - hitch receivers vs hooks #4
I have one center receiver mounted. Works great, use it for a homemade pallet/brush attach., moving trailers (all the time), and other attachments I've made. I mounted mine dead center on top. Added a 2x2 thick wall steel piece to the underside of the bucket to add some strength. You definately need to reinforce somehow.
I'll be adding one on either side as well. Sort of my own quick attach system.
Well, I have bought the parts. KiotiAcres, could you please describe the 2x2 thick wall steel piece for me a bit, I'm not clear. Is it a tube? Where does it start and end? How did you attach it? Sorry but I want to avoid damage to the bucket.
IXLR8, did you reinforce the bucket? I did not pick it up in your post.
/ Bucket mod - hitch receivers vs hooks #7
On mine, the receiver is welded to piece of 3x3 angle iron 16 inchs long. The angle iron is then bolted to the bucket with 4- 1/2" diameter bolts.
/ Bucket mod - hitch receivers vs hooks #8
I have two receivers and two hooks on my ck35.
I use them to hook up my forks, and hopefully soon my brush rake, if I ever get finished scrounging parts for it.
Though I've went back and redesigned how my forks attach. I no longer have to leave the seat to hook up.
The hitch mount that I got is welded to a plate of 1/4" thick steel that is 5" wide and 14" long. It is pre-drilled for 1/2 inch bolts (I have bought grade 8 bolts). The bucket I have is (barely) 3/8" thick steel and there is a 1" square tube welded inside the top front edge for strength. The top "flat" part of the bucket is 5ft long and 5" wide. Should I bolt another piece of flat stock to the entire flat top part or something else? Do you think the 5" x 14" plate is enough? Opinions?
/ Bucket mod - hitch receivers vs hooks #10
Ruby Goldberg Bucket modification!
Supplies:
2 x 6 receiver tube - tractor supply - $10.00 ea.
3/16 x 3 x 1/38 - 6ft. channel steel - metal yard - $20.00
2 receiver tow hook Harbor Freight - $8.00 ea.
3/8 weld-on chain hooks awdirect - $5.00 ea.
Ability to create and plug in a variety of helpful gadgets PRICELESS!
Tools:
Lincoln 135 flux-core
Hobart Stickmate Welder AC/DC
7018 Rod
Process:
1. I first ground off all the paint from the top of the bucket where I planned on welding. What a PIA. The paint just wanted to melt and gum-up the grinder.
2. Ditto for the receiver tubes.
3. Cut steel channel using a chop saw and dry fit all components.
4. Tacked receiver tubes into place on bucket with Lincoln flux-core.
5. Capped receiver tack weld with Hobart & 7018 rod.
6. Ground relief in channel to fit over existing welds on tube.
7. Tack welded channels to bucket with Lincoln flux-core.
8. Stitched with 7018 about every 4 inches.
9. Filled in between stitches with Lincoln flux-core
10. Tacked on 3/8 chain hooks with Lincoln flux-core & caped with 7018 rod.
11. Sprayed with automotive body primer, hey it's a working machine.
Strength? Well I had a couple of boulders to move so I lassoed them with a slip chain and tried to pick them up. I was able to barely pick up one of them up but not the other one I could not so I dragged it. The buck and hooks held up without detectable deflection though the loader arms were quite twisted on the one I was able to pick up even though it was pretty much centrally located to the buck the rock was not of uniform shape so it shifted the center of gravity. I considered this a maximum load test for me and my machine. I can never imagine using it to a greater capacity. I could imagine any form of serious jarring could bend or break something but I would consider that abusing the equipment so there are no guarantees there. I do have a variety of gadgets on the to-do list so as I create them I will post them.
/ Bucket mod - hitch receivers vs hooks #11
Great job! Now, where are all the cool implements you have designed and built to fit into the receiver hitchs? You've got a potential Kioti leatherman there waiting to be born. With a welder and chop saw I'd imagine the possibilities are near limitless. Of course you'd need also to build a portable storage unit for those implements so they are always handy. How about a "bumper dumper" for the middle mount, a toilet paper holder for the right side and a magazine rack for the left?:)
Seriously though, that set up has great potential beyond just forks, tree boom etc.
/ Bucket mod - hitch receivers vs hooks #12
I purchased a bumper hitch reciever from Harbor Freight for $19.99, and bolted it to the center of my bucket with 4 5/8" X 2" bolts.
Then I purchased a 6" drop hitch to go into the reciever and topped it off with a 2" ball. I move my trailers around with it all the time, but it is a challange backing up and steering the trailer to the correct position that you want. Kinda like getting used to driving a forklift with the steering on the rear. LOL
I also have welded grab hooks (1 on each side) to my bucket.
What I see here all looks good.
C-YA RL
/ Bucket mod - hitch receivers vs hooks #13
Island - Thanks for the compliment. :) I have a few patent pending ideas oscillating between the synapses in the left hemisphere of my well worn noodle. And I need to get them out as this is creating a rather peculiar imbalance as my right hemisphere is pretty much empty and it is causing me to walk with a list to port. The problem with getting them out is that my work space is unheated and I have attained an age where the body is highly disagreeable with the whims of the mind and protests rather vigorously against such abuses. So it seems I must await the return of the robins in order to empty the left side and return the equilibrium that I have come to enjoy these days. As soon as it happens I will share it, until then (yawn!) it's back to the recliner and another long winters nap!
(yawn!) -Steverino
Stevirino, I hope you can get that list settled off before it's too late!!!
InspectorGadget, that is the exact same bumper hitch thingee I have purchased. Cost me $10 more in Canada to buy it than you paid but I think it's perfect. I have a pal who owns a machine shop coming over today and we're going to design a bucket reinforcement of some sort. I'll post pics once it's done. I still worry that I'll bend the bucket without something such as Steverino has done as I intend to lift rocks and logs and hay bales via the hitch mount.
Thanks everyone for the ideas and comments.
/ Bucket mod - hitch receivers vs hooks #15
I went with the welded hook on center top of bucket and I purchased for $59 or so a clamp on hitch receiver. It works fine for the couple a few times per year I need to move my trailers around with something other than my truck.
I used my welded on chain hook all the time, many many many times, and the angle at which the chain hangs from the hook works great at pulling what ever it is I'm carrying tight to the loader.
Either way, super handy stuff to have on the loader.
Joel
/ Bucket mod - hitch receivers vs hooks #16
C-YA RL
Here are a few more close up shots I took this last weekend.
C-YA RL
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
2009 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2009 GREAT DANE...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
Hyundai Forklift (A65579)
Hyundai Forklift...
