Is PTO power the same as Tractor HP?
   / Is PTO power the same as Tractor HP? #1
Scotty370
Buffalo, New York
318 John Deere, 4200 John Deere, 1947 John Deere "M"
In my project in the Build it Yourself forum, I'm going to use a gearbox on an PTO driven grinder. If my compact tractor (JD 4200, 26hp) is hooked to it, do I have a margin of over-build using a 40HP rated gearbox?
   / Is PTO power the same as Tractor HP? #3
PTO power is always less than engine hp due to heat, hydraulic, and friction losses. Typically a gear tractor looses about 10% hp to the PTO and a hydro tractor looses about 25%. These are rough estimates and dependent on many factors.
   / Is PTO power the same as Tractor HP? #4
Tractors manufactured for use in Japan are rated in pto horsepower but tractors manufactured for sale in the US are rated in engine hp.
My Yanmar YM1802 was made to sell in Japan and is rated at 18 pto hp but the engine hp is approximately 22.5.
   / Is PTO power the same as Tractor HP? #5
almost got it right.
Most hydrostatic TRANSMISSION tractors (if not all) use a direct connection to the engine for the PTO (via clutch). the reason the PTO speed goes up and down based on engine RPM. therefore the HP diff between PTO and engine numbers is the same for both a gear and hydro (or shuttle shift, automatic, power trans etc) transmission tractors
what your thinking of (in the 20% loss) is when it comes to putting HP to the ground via the transmission. the hydro has a greater loss in converting the mechanical engine rotation to hydraulic fluid back to mechanical motion. with the trade off of infinite ground speed control and shock protection.
   / Is PTO power the same as Tractor HP? #6
My 26 HP Kubota produces 19 HP at the PTO.
   / Is PTO power the same as Tractor HP? #7
Maximum engine horsepower is typically produced at a higher RPM than PTO speed, so PTO horsepower will automatically be a little bit less than engine horsepower. Any mechanical losses in the PTO system will lower it even more.
Manufacturers generally provide both ratings.
   / Is PTO power the same as Tractor HP? #8
I'm hot sure I follow you, I just checked Mahindra 3215s. Both tractors have 32hp. The gear shows pto to be 27hp and the HST shows 25hp, both reach 540rpm at 2376rpm. How do both of these tractors have the same pto hp?:confused: Is this not similar on most tractor comparisons of this type? Yes the loss is because of the HST, but it is still a loss, the gear tractor always has more pto hp.
Am I wrong here? :confused: :confused:
   / Is PTO power the same as Tractor HP? #9
The HST pump runs all of the time absorbing some of the available horsepower. Thus, less HP at the PTO.
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
2011 Ford Expedition XLT SUV (A48082)
2011 Ford...
1996 Stoughton Semi-Van Trailer (A50860)
1996 Stoughton...
Knapheide Service Bed (A50860)
Knapheide Service...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
