lakespirit
I turn the key and nothing happens, no click, nothing, period. I can start by jumping across the terminals on starter and solenoid. I checked all the fuses and they are OK. This just happened without any warning.
Check the clutch interlock switch. It is in the starting circuit between the keyswitch and the starter solenoid. It's under the left floorboard, in a bracket right by the clutch pedal armI turn the key and nothing happens, no click, nothing, period. I can start by jumping across the terminals on starter and solenoid. I checked all the fuses and they are OK. This just happened without any warning.![]()
Did the temperature where the tractor was parked get above freezing between uses? If yes, the clutch interlock switch was likely just frozen. If ice and/or packed snow continue to be a problem, that will happen again. And unfortunately that switch cannot be conveniently relocated. The (less than safe) alternative is to just bypass it.Today the ignition switch just decided to work again???![]()
See my mod sheet at http://johnstractor.homestead.com/files/Ford_switch2.doc It's kinda old, and it's since been found that not all the Ford switches have the same post positions on the back. Plus, your TaiShan wiring will be a little different than the 200 Series Jinma (for which the mod was originally intended). But getcha one, and we'll work it from there.Greg,
Please provide some more info on the Ford switch.
Correct, old style key switch dating back 50 some years. Still common in most farm supply stores, you should get change back from a $20 bill. This cold start switch however, should not be confused with a cold start kit (starter relay, glow plug relay, alternator bypass). They're two separate projects.Greg,
Are we talking a Ford tractor switch?
