Power Out - Day Two
   / Power Out - Day Two #81
We have grey,yellow and green seals for our meter sockets.They only give us lineman the grey color tags.The meter shop installs the other two colored ones.coobie
Coobie, what is difference in the colors? I never payed any attention and did not know there were even different colors.
Chris
   / Power Out - Day Two #82
Chris
The grey ones are for new business & resident meters.The green are for turned off meters.Not sure what the yellow ones are for.coobie
   / Power Out - Day Two #83
Are you a idiot or do you just like to argue
Chris
I love to argue... doesn't everybody?
The way I see it, you guys just gave complete instructions on how to get somebody killed, to an audience full of people that know just enough to get it done.
I have a generator panel. I'm too lazy to install it as of yet. When the power goes out I run some extention cords, I don't risk someone else's life because I'm lazy.
Jake
   / Power Out - Day Two #84
I'm trying to avoid a complete seperate sub-pannel as I would like to power the entire house, not just certain circuits.
Joel
You've got both options mixed into one idea there Joel. To power the whole house you need the Main service panel that has the generator switch built into it. The sub-panel switching panel is alot less $.
Jake
   / Power Out - Day Two #85
Flip the main, feed in your 220 from the generator to your dryer outlet. The outside is isolated. Linemen should be checking for voltage along the way. In NO WAY AM I condoning hurting anyone.
I climbed the poles for 4 years prior to getting into IS/IT in what is now Verizon. Every time we went out we were required to check for voltage with our wand. I got quickly reminded once when I encountered a hot mobile home that wasn't grounded properly.
In that case the mobilehome had not had power for awhile, the utility fired it up and never checked that the ground was broken at the meter.
   / Power Out - Day Two #86
In my area the customer is responsiable for the ground at the meter socket.Alot of time the phone companies hook on to the customers ground rod at the meter socket which can cause problems.We are responsiable for the wire going to the weatherhead,or under ground wire going to the bottom of the meter socket.coobie
   / Power Out - Day Two #88
Question...
I'm considering installing a wind turbine in the backyard.
When we are not utilizing the total output of the unit, the excess will be "backfed" into the grid (perfectly legal) and I will get credit (meter runs backwards).
When the electricity goes out, the turbine will continue to produce (hopefully). Nowhere have I found a requirement to have an auto cut-out switch to prevent the backfeed.
The power company and the county say I don't need one.
I don't want to hurt anyone, and I'm sure this scenario is carried out thousands of times a day.
Any ideas?
Tom
   / Power Out - Day Two #90
Jake
Yeah running little cheap extension cords all over the house, ya know 100 footer plugged into a electric space heater, getting slammed in doors, getting wet, etc has never caused any problems. :D
I'll take my chances backfeeding.
Rob
JOHNSON 6HP OUTBOARD MOTOR & STAND (A58374)
JOHNSON 6HP...
2004 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A58018)
2004 FREIGHTLINER...
Terms & Conditions of (Buying through EquipmentDealz Auction) Final (A59213)
Terms & Conditions...
2019 Chevrolet Tahoe (A55973)
2019 Chevrolet...
Mower King Brush Cutter (A53317)
Mower King Brush...
2022 DODGE RAM 2500 SERVICE TRUCK (A58214)
2022 DODGE RAM...
