Case 310G dozer update
/ Case 310G dozer update #1
rtimgray
Well, I've had my dozer for over a year now (I had to look on here to see when I bought it - about October of 2007). I've got to say that I think I got a pretty decent deal. I've used it alot for the first year and have had no major problems. I've done quite a bit of clearing, cleaned up brush/dozer piles from previous years, filled ditches, and in August/September dug a small pond (about a 1/4 acre). It's even holding water!! (Pretty good luck for my first pond try).
I've put on somewhere in the neighborhood of 70 to 80 hours on it (about 1/2 of that was the pond, so it was just dirt pushing). The rest has been clearing - and it'll take down trees much larger than I thought it would. It does have the same problem that Eddie Walker mentions to most folks that ask about dozers - it's not to bad to take trees down; pushing a big pile of them together takes a bigger machine. However, I've got more time than I have money to invest in a dozer, so I've okay with making a few more trips.
So far, I've changed all the fluids and filters through the course of the year, and it burns about a quart of oil in 10-15 hours depending on how hard I'm running it (for a 40+ year old machine, I didn't think that was too bad). It starts good in 40 degree and above weather, below that I have to jump start it and add starting fluid, but it cranks quickly after that.
It's not too hard on fuel - probably about 1/2 gal to 1 gal/hour depending on what I'm doing, of course. The only thing that I know I need to do soon is adjust the tracks. They have gotten a little loose over the course of the year and I bet it's better to tighten them now rather than after I throw one!
Overall, I'm very happy with my dozer. I don't know that it has quite paid for itself yet, but it's getting close. My dozer is alot more similar to a tractor than a dozer as far as working on it goes, so it's nowhere near the class of Cat D6 or Case 850, etc. But with a little time, I can get a lot done.
Just thought I'd share my good experience with the old dozer.
Take care.
/ Case 310G dozer update #2
Glad to hear of your good fortune. I have a Case 310 diesel track loader and it is a real work horse. I have no complaints but if I get a bigger hp tractor I may have to part with it.
Anyway, they are great machines and I'm sure it will serve you well.
That looks like a really nice loader (at least it's cosmetically much better than mine).
Is it very hard to get on and off of (just looking at the loader supports)?
Take care.
/ Case 310G dozer update #4
That looks like an F150 pulling. How much is that load? I would have thought it too much for an F150, but since you are doing it...
jb
jb
I think that mine weighs 9,000 to 10,000 lbs with the blade, so I bet his is similar (my weights come from what the manual says, as I have never weighed it). If I had a trailer strong enough (and it looks like the trailer is built for it), I wouldn't worry about pulling it with a pickup. I might not want to go too far or too fast, but with some care it would probably be alright.
However, my dozer only crawls around our farm, so it's not going for a ride anytime soon.
/ Case 310G dozer update #6
Im pretty certain thats either a 250 or 350 pulling that dozer in the picture a few posts up...
/ Case 310G dozer update #7
Yeaaaaaaaa........baby! Dozer are a lot of work to rebuild, but hard to beat when you really need the grip. :D
/ Case 310G dozer update #8
I thought it had the Harley Davidson trim package and that would make it an F150, no? More curious than anything..
jb
/ Case 310G dozer update #9
jb
HD Packages were originally F150 only, with a supercharged 5.4L V8.
Later versions were F250's with the 6.0L diesel.
The badge on the back looks more like a "King Ranch" to me, but I've been wrong before...:D
/ Case 310G dozer update #10
Thanks for the update. It's nice to hear of your success and good fortune!!!!!
My latest discover, if you can call it that, is just how much faster and easier it is to get trees to the burn pile with a grapple. Just pick them up and put them in place. If the tree is to big to pick up whole, it's worth the time to cut it in half or quarter it with the chainsaw. Not that the dozer can't put them into a pile, but the dozer also adds allot of dirt the burn piles, and that's almost as much work to clean up ans getting the trees there.
I've never run a Case 310 and don't know the HP of it. I did run a John Deere 450G for awhile, and working those levers to steer, along with the blade was a workout. My arms never stopped moving!!! At 80hp, maybe less, it's amazing at what the smaller dozers can accomplish. Of course, with more HP, you can get away with things that you can't on smaller machine. I'd imagine you could do anything with yours that I can with mine, it just takes a bit more planning and time.
Eddie
/ Case 310G dozer update #11
jb
I believe that is an F150 with King Ranch package. And I would bet that if the Indiana DOT looked at that combination, there would be a pretty stiff fine handed out.
/ Case 310G dozer update #12
Hi Campers,
I have a case 310 dozer with mechanical track adjusters....annnnnnnnnnnnd....I threw a track ( oh boy) . Here is my question. On the adjuster there is a nut, which I backed off, is there anything else I need to do before pushing the wheel back with my bucket loader?
thanks in advance
unclehubcap
/ Case 310G dozer update #13
Hi Campers,
thanks in advance
unclehubcap
Unbelieveable! Use a come-a-long.
/ Case 310G dozer update #14
Hi Campers,
thanks in advance
unclehubcap
Hello,
I have a 310 Case track loader I bought last year to restore, I'm getting all the mechanical fixed first. On mine their are 2 nuts 1 locks the other in place.
I never had a track come off but have adjusted the slack out. I would say you have it backed off enough to to get your track on. There are no other bolts, nuts ect
to my knowledge you have to loosen, the hard part is getting the track on, after you get it on, adjust it till all the slack is out. I attached some pics I took this evenong
after seeing your post, hope this helps.DSC03177.JPGDSC03183.JPGDSC03178.JPGDSC03182.JPGDSC03176.JPGDSC03175.JPGDSC03183.JPGDSC03178.JPGDSC03186.JPG
/ Case 310G dozer update #15
Duke,
Thanks for your help! This is my first dozer, so I was pretty much shooting in the dark. The track is back on and it wasn't as hard as i would have thought. It took a torch to free the nuts and a BIG bar, but it is done and i learned alot. Thanks again for your help.
hubcap
/ Case 310G dozer update #16
unclehupcap,
Glad everything worked out good. I have a owners manual, if you need any info. about fluids, ect. feel free to contact me.
Duke
2006 TerraGator 8104 (A63688)
2006 TerraGator...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
Wolverine 84" Quick Attach Snow Push (A66285)
Wolverine 84"...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
