Squealing control valve
/ Squealing control valve #1
bar
Penacook, NH
Zetor 3340
I have a problem (that may be unique) that I couldn't find any information on from a search. I have a Zetor 3340 with an Allied FEL. I have fabricated a frame for a power angle plow blade and bought a Prince 4-way, open center control valve to control the power angle function. The Zetor system is 8.5GPM @ 2600PSI, open center. I wanted to keep the loader tilt function for the blade so didn't want to use either of the loader controls for the PA function.
I connected the FEL control output to the input of the Prince control and returned the output of the Prince control back to the tank. The Prince has a check valve at the input to prevent reverse flow. The A & B ports go to a pair of SA cylinders.
Now the problem. When I angle the blade it moves far slower than I expected and the Prince control makes a whining noise. The FEL controls still work fine.
Pressure relief on the Prince control is at factory setting of 1500PSI.
Can anyone tell me if there is something inherently wrong with this hookup or have some thoughts on what the problem could be.
Sorry its so long but wanted to provide adequate info first time around.
Thanks for any inputs. bar
/ Squealing control valve #2
Sounds like the relief is opening. What range of adjustment is available on the relief? I assume the Prince valve is rated at least 2600 PSI.
Is there a proper path for the fluid to flow back from the single action cylinders?
/ Squealing control valve #3
Squealing is usually cause by the PRV (Pressure Relief Valve) as SR just indicated. The relief on the new valve should be set close to or at the system pressure for your system.
One other problem that could cause it since you indicated slow operation would be a restriction in the lines...you didn't go crazy with Teflon tape did you?
kennyd & SnowRidge, Thanks for the responses. I thought the noise was from the relief valve. Prince PR range is 1000 to 3000 PSI and spec sheet says its preset to 1500PSI.
I have read not to use teflon tape. I used teflon based paste and was careful to keep it below the first thread of NPT fittings. I checked valve performance with air and the valve worked as expected ie with port A enabled, Port B was open to the return line.
I think it must be a restriction. I used one of my new 15' lines when testing the valve with air but didn't test the other one. PA performance acts the same in both directions.
If I use the PA function sparingly will it cause any damage to the system if I don't fix it before warm weather next spring?
/ Squealing control valve #5
Adjust the relief to match your system pressure under normal operating conditions. Your system is delivering more than 1500 PSI, so the relief opens. You really should put a gauge on it to see exactly what the pressure is when it opens.
/ Squealing control valve #6
Yeah, Get a gauge and set it properly...You can but them online or at TSC for under $20. You will also be able to check your other PRV's to see if your whole system is up to spec.
/ Squealing control valve #7
It is possible that the prince control valve has a "power beyond sleeve" installed in it witch would block the return oil comming from the angle cyls. it would be a big nut with a sleeve atached to it at the outlet port of the prince valve. I would not increase the pressure stetting on the prince valve. you might run into trouble if you use the factory control valve and the prince valve at the same time.
/ Squealing control valve #8
That is an excellent thought!
What trouble could you run into? Please explain why you would want a relief set so low in a system that's max pressure is probably 2000-2500 PSI?
/ Squealing control valve #9
Hi adjust the relief valve on the prince right up you should already have a relief valve in the main fel valve as well as the tractor relief we do this all the time and have not had a prob in the last 20+ years unless you play with the main releif or the fel relief you are going to be safe 1500psi is way too low for proper operation:)
The Prince valve does not have the large nut near the outlet port. I pretested the valve with air and know that air passes freely thru the valve from input to output when the control is spring centered. When I tested with air for which control position activated port A, I had to remove the inlet reverse check valve to get air thru because of the low pressure I was using. What I don't remember doing is testing to see if port B was open to the return line when port A was activated. I guess I'll have to disassemble and test for that .....and none of my many fittings leaked first time around!!http://www.tractorbynet.com/forums/images/smilies/smile.gif or call Prince. Would a standard 4-way control valve be designed that way?
Regarding system pressure, Isn't pump operating pressure dependent on load? The power angle frame is greased and can be swiveled by hand very easily with the cylinders disconnected.
I don't plan on ever operating the FEL controls and the Prince control at the same time.
Thanks again for all the responses.
bar
/ Squealing control valve #11
I'm wondering if you have a valve designed for use with double acting cylinders.
/ Squealing control valve #13
Yes, that is correct, but the PRV sets the max pressure.
It should be, can you provide a link or part number for the valve you are using?
Yes.
/ Squealing control valve #14
If you are using the factory valve the return oil will be going thru the out side passages of the valve. the return passages are not rated to see high pressure. that is why you should have a power beyond in the first valve in line. You should never see High pressure unless the cylinder is at the end of its stroke. One thought that just came to mind is maybe the angle cyl are plumed wrong, they could working against each other
/ Squealing control valve #15
Two SA cylinders are pretty hard to plumb wrong!
He is using a valve with a check valve on the input, so there should be no reverse flow putting pressure on the OUT port of his FEL valve.
Possibly this new valve is a regenerative type, and that is causing the slow movement...Won't know till he post's a link and/or part number.
/ Squealing control valve #16
bar:
You may have reinstalled the load check (also called lift check) improperly. If it is not opening properly, the flow into both the A and B ports will be restricted, but flow through the valve (when the spool is in neutral) will not be restricted.
With most lift checks, you can just remove the poppet valve and spring entirely and then reinstall the plug without them. You won't have a lift check, but if the valve then works properly it will confirm that you have a problem with the lift check. Since you are not lifting a load, I don't think removing the lift check will create any problem.
/ Squealing control valve #17
If there is any kind of restriction anywhere downstream from the OUT port on the loader valve, check valve or not, pressure will build in the loader valve.
/ Squealing control valve #18
You would think ,after all the years since hydraulics was installed on tractors and other machinery, that the manufactures would put a hydraulic gage in the system for troubleshooting and maintenance. For less than $50.00 , everyone that owns/operates a tractor and other machinery could install a gage system to do their own diagnostic/problem solving. It simply involves a gage with QD's to plug into the system at key points on the tractor. An ideal setup would include a gage with a magnet attachment and a 1/4 hydraulic line,and when plugged into the matching QD, you can satisfy your self that the system is working or not working as advertised.
/ Squealing control valve #19
Sorry I missed the part about the SA cyl.
To clarify my point if you are raising the FEL all the oil from the pump is going to the cyls and is protected with MRV the oil comming out of the return side of the cyl is flowing back to the valve and thru the return ports of the valve and out to the tank or in this case the prince valve. That oil in most valves is run around the out side where the casting is thin and has no protection or RV. now if you use the prince valve and it builds to MRV pressure you will see that pressure back to the FEL valve and the return passages. with or without the check valve at the inlet of the prince valve. I realy don't see the need for that check valve in this system. The proper way to add a valve after the FEL valve would be a power beyond sleeve in the FEL valve and a return line from the FEL valve to tank. most tractor MF sell PB kits. In this case if they don't then I would put a PB in the prince valve and put it before the FEL valve Ed
I first of all want to thank everyone for taking the time to think about my problem and respond accordingly. I haven't done any further checking but I will after the holidays and report back here when the problem is resolved.
kennyd: The PA valve in question is a Prince RD2575.
Although there will be no reverse flow thru the FEL valve, there will be pressure. This pressure will be slightly higher than that required to angle the plow (loss thru the check valve) and per my current problem that will be the Prince relief valve setting of 1500psi.
abcrepair: I was unaware of the potential problems from back loading the FEL valve. That is good information. I considered putting T's on the FEL valve and running the valves in parallel but was told the series connection was good ..... and the plumbing seemed simpler. Guess I need to study up on PB.
I will get a pressure gage but at this time I feel there is a restriction problem and the Prince relief valve should not require adjustment. It would seem the problem has to be in the new 1/4" lines going to the SA PA cylinders, the QD couplers attached to the Prince valve or the valve itself. Unfortunately I used none swivel type NPT F couplers to add the new lines back to the control so disassembly will be cumbersome and I don't have spare mating parts for the QD's at the valve. But I will disasemble the suspected components and test them in my shop with air. I will also double check to make sure there is no mechanical hangup producing an excessive load but I think that is doubtful.
bar
We do NOT accept credit cards as payment. (A64911)
We do NOT accept...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A66736)
2018 Chevrolet...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2019 John Deere TX 4x2 Gator (A64912)
2019 John Deere TX...
2014 Infiniti QX60 SUV (A66738)
2014 Infiniti QX60...
TQ 125 Generator (A64912)
TQ 125 Generator...
