car test photo
/ car test photo #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Just trying to skip the Photobucket thing and go direct off my photos. Thinking of building a car like this
/ car test photo #2
Those were the dream of many a young fellow just yesterday or was it 50 years ago?:D:D:D
/ car test photo #3
That's a nice car, the only thing I don't like about it is the low hanging exhaust.
/ car test photo #5
Nice car,hope you have alot of time its a lot of work , but fun here is my 36 ford
/ car test photo #6
I hate to admit it but 50 years ago is closer.
I know because I got my first car in 1958.
That was exactly 50 years ago.
What was your first car?
Mine was, and I rarely mention it to anyone because it is embarrassing, was an Austin 1100 ...with an automatic no less!!! Couldn't even spin the tires on gravel ... come to think of it, maybe it had traction control. :cool::cool:
/ car test photo #7
1*What was your first car?
1*It was a 1950 Chevy 4 door sedan.
This is my 1950 Chevy 2 door sport coupe .
I've owned it since 1976.
L . B .
/ car test photo #8
Nice. The tranny in my 1100 was no Powerglide I'll tell you! It was 4 spd though, chain-driven and shared lubricating oil with the engine, usually a recipe for disaster. Hmmm...my Traxter ATV does too.:eek:
/ car test photo #9
My first vehicle I ever bought was a Hummer. Yep. . . I ain't tellin' no fibs.;)
/ car test photo
That would make a great Rat Rod, but a bit too shiny isn't it?
I'm 60 years old so shiny is OK and desirable. Figured to find a model A coupe (or roadster), with shiny black paint and slide the body onto a new frame and suspension. I have done this stuff for decades. Small block 350 w/ 5 speed and call it good. Figure I could build it in four months if I paid attention.
/ car test photo #13
Four months? You'll have to pay more than attention to get it done in four months. Maybe, if you didn't have to make anything. But that's just assembling, not building. ;)
This is 31 Ford Tudor, mild custom. SBC 350/350 on an aftermarket chassis. All steel except for the front fenders. The wood bow roof was replaced with steel. Hand made the floorboard and seat risers. The body was twisted and in the shape of a banana when I got it. You couldn't close the doors. This job took almost a year working about 50%.
/ car test photo #14
This one took nearly the same.
/ car test photo
Both of the above vehicles are very nice. I do like the two door and the truck is a parade-stopper. Figured there are a lot of "A" coupes around and I like the look. I would go un-chopped for the top and just run a nice stock body.
I figure a few months ( I have done it before) because I will buy a nice body that is in excellent shape so I spend no time on that. I'll buy a new frame and kick up the back myself so little time there. I have both "built" and "assembled" things over the years and a combination works OK. The guys from the '60's would fully approve and we longed for some better way to put things together. A new frame built on a jig solves a lot of future problems.
I once spent a winter chiseling the rivets out of two '37 Chevy coupe front ends to convert from the Master DeLuxe knee-action shocks to a "Master" stock straight axle with six bolt hubs. Not all the crossmember holes were in the same place so I had to drill holes with 1960's drills and bits. Then I needed an adapter machined to adapt to five bolt wheels.
Today you can buy a Magnum axle, torch or grind off the old rivets, install a better crossmember and be done in a day. Plus I feel better on the Interstate in the blind spot of a semi. It's not truly home built but a close second maybe?
(4) RUBBER TIRE LOADER TIRES (A62613)
(4) RUBBER TIRE...
Power command Transfer Switch (A62679)
Power command...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
Cub Cadet XT1 Riding Mower (A66285)
Cub Cadet XT1...
