New Pick em up Trucks
/ New Pick em up Trucks #22
Sorry but I don't buy it. There is no way you could put 6,000lbs on a 1970's 3/4 ton truck and actually drive it. I have had 5,000lbs in the back of my 94 F-350 dump truck and the rear springs were pretty flat. A 3/4 ton truck would snap in half with that kind of weight.
I was hauling gravel from a gravel pit at the time and got the truck weighed before and after loading .
It weighed about 6000 pounds more after loading than it did before.
This was not a stock 3/4 ton but a beefed up heavy duty camper special.
/ New Pick em up Trucks #24
I still have my 1999 F250 gasser and the rear springs on the newer trucks are just too soft when pulling trailers. My 1999 F250 at that time had the same rear end axle and springs as a F350 except the F350's had a 2" riser block on the axle. My old F250 just stayed level despite the loads on the bumper. I have the camper package on the new truck with the extra springs, but it still sags too much. The newer F250 does ride smoother which is the trade off. I did drive a few of the newer F350s and the ride still seemed very good and not a significant difference from a new F250.
I have a 1999 F-250 SD and do I understand you correctly that the only difference between the F-250 & F-350 SRW's for 1999 are a couple of riser blocks on the rear end and some badges? I seem to recall seeing something from Ford that confirms your statement about the 1999 F-250's & F-350's have the same rear axle & springs.
/ New Pick em up Trucks #26
I know that he left out GM in his original post. If you are steering him towards Diesels then he might want to look at GM. As far as anything I have read on duramax is the only major problem they had was in the 2004 and earlier with cracked injectors and those are made by bosche who makes injectors for all three american brands I believe. They redesigned the heads and went with different injectors in late model 2004 and above. I have not heard any serious problems since. As far as transmissions go I dont think anyone makes anything as good as the allyson transmisson let alone better. Every article I have read by companies that beef them up, all the reports I have read that behind a stock engine they are almost entirely bullet proof. I am sure someone will tell a problem they have had with one but they are either running behind a engine with more HP and torque than stock or are just a very rare example. If I was looking I would try to find a low mileage 2006 or a 2007 classic and stay away from the 2008 unless you just want the new body style. The engine is the same from 2006 and so is the transmission. In 2008 they went to the exhaust emission add ons and I am happy I dont have to deal with those in the 2006
/ New Pick em up Trucks #27
I would like opinions of what is good out there in the market place now.
I like Toyota, Nissan and Ford. Ford's employee pricing is looking pretty good right now.
I am leaning towards a 2008 F250 XLT super duty with the trailer towing package.
I have not heard much about Titan. The Tundra is nice expensive. Super duty should be pretty tough.
I am open to suggestions. Hoping to buy yet this year.
TIA
Yooper Dave
Yooper Dave.
You're thinking of buying a new truck and you're considering the Ford 250 XLT. Great choice, but before you spend your hard earned money, be sure what you will be doing with the truck. Know beforehand what loads you will be pulling and/or hauling. Will you be towing a 5th wheel or goose neck trailer? A heavy bumper pull trailer? How many miles will you be driving it, daily and those long trips. If you've decided on a HD Ford (great choice) consider very carefully which engine would be best. I guarantee with diesel fuel at over 50% more than gasoline today and with the new diesels burning considerably more fuel than the old ones. the V10 gas engine would be on my short list. There is NO economic payoff anymore for buying a diesel, it's best only when the work intended exceeds that of the gas engine alternatives. You could do different from a ford HD, but I can't imagine you could do better for all around transportation and occasional hard work and light duty trips. Before you buy. know the weights you will be pulling and hauling, the GAWR, GCWR, and GVWR ratings of the truck you're loooking at and compare them with your intentions before you buy it.
/ New Pick em up Trucks #28
That was just cruel
Yeah, I guess so. But everyone has already put in the serious content only leaving the comedic!
But seriously, I would take Crash101's advice further and determine if you REALLY REALLY need the HD truck at all. The new F150, Dodge and (even better) GM have all improved in every way from HP to capacity and all have better MPG's than they did in 2001. The weight penalty in the HD line of trucks is with you every day, but the extra capacity may NEVER EVER get used.
jb
/ New Pick em up Trucks #29
I have also hauled around 50 loads of gravel from a pit that weighs you on the way in and then on the way out. 4 or more times out of the 50 loads the reading was incorrect going in so my 7500lb truck was weighing in at like 4500lbs, then when I leave and the truck is at 11,000 or 12,000lbs they try to charge me for 4 tons of material. I show them the other 20 or so slips in my glove box that show the truck weighs 7500lbs give or take 100lbs depending on gas level and they correct it. These scales are made for large tractor-trailers weighing in excessive of 20 tons and if they are off by 2000lbs it is not enough difference (<10%) to warrant a recalibration. But when a little 1-ton truck comes in and it is off by 2000lbs it is a 30% difference.
I would be willing to bet that is what happened in your case. A stock 3/4 ton truck will not carry 6,000lbs even if it is a "camper special" which just meant one more helper spring.
/ New Pick em up Trucks #30
jb
I agree with you 100 per cent. I look at the new 1/2 gmc and for most of the time they would more than do what i need. The main reason I bought a diesel was because I am old and always wanted one :) I could easily get by with a 1/2 ton gas for 95 per cent of my useage
/ New Pick em up Trucks #31
I had a new Ford F 250 3/4 ton Camper Special back in 1971.
3 or 4 thousand pounds was no problem on it.
Some how I can't fathom a 1/2 ton being able to handle that much weight.
Are you saying today's new 1/2 ton would handle towing my BX23
on a 16 foot trailer better easier and safer than the old 71 3/4 ton Ford would have?
That's kinda hard for me to believe.
[/quote]
/ New Pick em up Trucks #32
Any 1/2 ton truck even with the base engine could pull around your BX23 and all the implements you want. My tractor weighs 5,200# with out the Backhoe but with the grader blade on the rear and I tow it fine with a tandem axle trailer and any of my trucks and have towed it numerous times behind a 2004 V8 Mercury Mountaineer. And yes, any new 1/2 ton truck would be much safer to pull any trailer with up to its max tow rating than any 1970's era truck. The breaks, tires, ect, ect, ect are so much better.
The new F-150 has a trailer stability feature built in that works much like vehicle stability control on every truck, even the base model. They have the option of a integrated pressure driven electric brake controller that is hands down 10 times better than any aftermarket brake controller sold with one exception. That would be the aftermarket systems that tie into the master cylinder like Brake Max. By the way GM also offers a brake controller but Toyota, Dodge, and Nissan have yet to. The max payload on the New F-150 is in the 3,100# neighborhood and the max tow rating is 11,300#. So yes, these new trucks by all the manufactures are hands down better and tougher than 70's and 80's 3/4 ton trucks but that is just progress. In 15 years these new trucks will be relics also.
Here is a link to the F-150 if you are interested in checking it out:
2009 F-150 Pickup - See pricing details, truck options packages and more | Ford Vehicles
Chris
/ New Pick em up Trucks #33
Yooper
You didn't really specify your needs which makes it somewhat difficult to offer valuable information. You did offer quite a spread of choices in your initial post. The Titan and F250 don't have much in common.
A couple of premises that I used in my own recent truck purchase:
1. There are no bad choices; they are all pretty good.
2. The "right" size truck is always better than the "supersize" truck. It's easy to talk yourself into something bigger than you may need. Decide what you need and stick to that segment.
In my purchase the right segment was the half ton:
1. I'm not in a trade and only use my truck for recreation. I have something in the back of it or on a trailer nearly every weekend but nothing that a half ton cannot handle well.
2. I have a young family so I needed a double cab with all the entertainment goodies.
3. I wanted it to have some pep.
That led me to a Toyota Tundra Crewmax Limited 5.7. Could I have been satisfied with a Ford, GMC, or Dodge? Probably. Nissan? No way! The right deal and the right financing came together for me and I have been very pleased.
There is plenty of good information on this board but I don't think you will get the "best stuff" until you provide some more detail as to your needs.
Good luck,
Joe
/ New Pick em up Trucks #34
1*Any 1/2 ton truck even with the base engine could pull around your BX23 and all the implements you want.
And yes, any new 1/2 ton truck would be much safer to pull any trailer with up to its max tow rating than any 1970's era truck. The breaks, tires, ect, ect, ect are so much better. Chris
1*This sounds so odd to me after being advised on this board for years that I needed a 3/4 ton pick up to handle the BX23 and a 16 foot trailer.
Back in 2004 and 2005 nearly every one replying to me about this said i needed a 3/4 ton pick up.
I bet the 3/4 got the vote in 97 to 99 percent of the replies I received .
What has Changed since then ??
/ New Pick em up Trucks #35
Everything has changed. You do not need a 3/4 for a BX tractor. Would it be nice, yes. I am not sure what your tractor weighs but I am guessing 2,500# or less with a loader. Even with a 2,000# trailer a Ranger would handle that job. Like I said my tractor weighs 5,200# and my trailer weighs about 1,300# with the chains and spare tire on it and I have pulled it 110 miles each way a half dozen times with a Mercury Mountaineer V8 to my inlaws multiple times.
Chris
The attached picture shows my truck during a deck building project.
I am now considering a 2008 F150 4x4 super cab. It is over $11,000 off original MSRP.
It should also be more heavy duty than my 2001.
I tow my tractor on a tandem axle trailer once in awhile. What I really wanted was more payload as indicated in the attached photo.
The F150 is more agressively sale priced. F250's are less discounted, and very difficult to find at this date.
The Ford propaganda machine was also impressive at the dealership. Ford looks pretty good.
Yooper Dave
/ New Pick em up Trucks #37
Do you know the payload differences between your current 150 and the new '08's?
We just bought a new '08 F150 XLT xtra cab 4wd w/ the 5.4L. Nice truck. I've hauled a full pallet of wood pellets (2000lbs) 3 times. It handled it ok, though over weight. I hauled our horse trailer almost 250 miles at a steady 65mph in hilly New England and it never hit 3000RPM even on a long hill. This w/ 3.55 gears, which I believe are the tallest offered. I was told the trailer weighs 3800lbs empty, though that seems high to me. I think you'd really notice if you approached max towing capacity. Overall, I think our truck is an excellent value.
/ New Pick em up Trucks #38
Boy, you sure need the trailer that day. Here is a pic of my deck project. I had 3 loads like this. The trailer is a 18' tandem 7,000# unit and its behind my 2004 F-250 4x4 Power Stroke.
Chris
/ New Pick em up Trucks #39
Chris
Forget something? :D
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
2004 International 8600 Tender Truck (A63688)
2004 International...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
