Kubota models comparable to Cub Cadet SC2400
   / Kubota models comparable to Cub Cadet SC2400 #11
Kubota bx2350 vs cub cadet yanmar sc 2400
Kubota is 54.8 Cu In engine
Yanmar is 55.1 Cu In engine
Kubota is 1322 lbs
Cub Cadet Yanmar is 1280 lbs
Kubota 3pt lift 24" behind pin is 670lbs
Cub Cadet Yanmar 24" behind pin is 661lbs
Kubota Fuel Tank is 6.6Gal
Cub Yanmar Tank is 5.8Gal
Kubota LA243 is 1st numbers and Cub Yanmar is 2nd set of numbers
Max lift height at bucket pin 71.3 in - 71 in
Dump clearance 52.4 - 54
Reach @ Max Height 28.9 - 28.5
Dump Angle 45 degrees - 45
Digging depth 4.7in - 6 in
Bucket width 48in - 48in
Raising time to full height w/o load 3.5sec - 3.5
lowering time w/o load 2.7sec - 2.5sec
bucket rollback 2.4 - 2 sec
bucket dump 1.7 - 1.5 sec
Rated Flow 3.7 gpm - 3.5 gpm
Relief valve PSI 1778 - 1780 PSI
Lift Capacity 500mm fwd max height 518lbs - 550lbs
Lift Capacity pivot pin max height 745lbs - 700lbs
Kubota Breakout Force 500mm fwd 992lbs - Cub is measured at pins 1350lbs
   / Kubota models comparable to Cub Cadet SC2400 #12
Kubota is 1322 lbs
The other big issue would be price, which you would have to check our your self for local price. I know my local price the Cub/Yamar is lower in price.
KC
   / Kubota models comparable to Cub Cadet SC2400 #13
Would think the Kioti CK20 may be a viable option.
It's not comparable in size to the SC or BX machines - it is quite a bit larger, and much heavier.
   / Kubota models comparable to Cub Cadet SC2400 #14
It is full size but it is price much less than standard B machines, it will also take a full PHD.
KC
   / Kubota models comparable to Cub Cadet SC2400 #15
KC
That depends on where you are. Out here, Kioti is priced above the bigger name manufacturers machines, and dealer presence is pretty poor.
   / Kubota models comparable to Cub Cadet SC2400 #16
Not out hear, it was price to move, 11900 tractor/FEL plus tax.
KC
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
