Is it just me, or does this go too far?
   / Is it just me, or does this go too far? #61
Willl said:
The stuff I posted ?
If yes, I also wondered, heck, it's not even in their manual. Nothing.
Even the unit weight is no where to be found.
FYI, here's the weights.
It cant be accurate - it has the 2305 being faster on dump and rise cycle rates than the 2520. The 2320 & 2520 have higher PSI ratings than the 2305, and the 2520 has the flow. But they have the 2305 lifting specs at or above the 2520. Its a total mess with this spec that was posted.
   / Is it just me, or does this go too far? #62
So it HAS to be OFFICIAL Deere marketing material...
   / Is it just me, or does this go too far? #63
LOL!! good one - you may be right
   / Is it just me, or does this go too far? #64
Looks like Kubota is up to the same tricks. The 2006 full line brochure shows the LA243 loader has lift capacity of 745 lbs, with no mention of how they got that figure. On the larger tractors they seem to list real numbers and indicate where they got them. Makes me think that the market for the SCUTs is more apt to brochure shop and compare numbers - therefore the manufacturers apply appropriate marketing with big numbers. Does make it hard to find out what is reality, and more importantly, what really matters. I'm gonna flip a coin, or let my kids decide what color they like better - green or orange!
   / Is it just me, or does this go too far? #65
Actually I have some real life feedback and pictures to boot - I was using my 2520 and BH today for the first time since I traded a 2320 in for it -
anyway the concrete was buried in my garden and I discovered it with my tiller - a few minutes later a mutant potatoe was unearthed -actually this conrete garden produces nice slabs that weight a mere 1000 lbs or less.
In this case Im pretty certain it was 800 plus pounds. It had my backhoe and the loaded tires 420 lbs each looking light in the rear loofers...
Anyway I removed it and the 2520 had speed and power to spare at max. height. Its significantly stronger and faster than my old 4100 ( and that was a perfomer)
Anyway enjoy the pictures..
   / Is it just me, or does this go too far? #66
Kubota uses metric numbers for their loaders lift capacity; if you multipy 243 X 2.2, that will give you the actual lifting power of 535#. Hope this helps.
   / Is it just me, or does this go too far? #67
MessickFarmEqu said:
John Deere 2000 Series Compact Utility Tractors
Lift up to 1277lbs†
"†Up to 1.5 meters or 59 inches."
I've got a problem when tractor companies do this. I think we are starting to verge on deceptive advertising here. Right on the main page for the 2000 series Deere is claiming that the 200cx lifts 1277 lbs. But keep reading, no where does it say where they came up with that figure. Its over double the loaders real world performance! In all liklyhood its from the pivot pin where no loads are lifted from. In the fine print they point out that its up to 59" - so its not to full height where every other company takes their measurements. At somepoint someone is going to have to file a false advertising lawsuit to stop these kinda things. There are too many companies stretching the truth too far. The average comsumer has no idea what they are buying and no fair basis for comparing two machines.
Yes, I am a competing dealer - however I'd be saying the same thing is Kubota or New Holland did this stuff. I've called out Mahindra and Kioti for doing this too. This instance deserves mention though because its the first time I've seen anything measured below full lift height.
Well Kubota L39 Specs seem suspect to me because my L39 never had the +3500 lb curl force advertised. Yes, the pressures were checked by dealer. Kubota also rates the lift at 2200 lbs but I doubt it has much more than 1600-1700 Lbs lift.
Whatever happened to being conservative?
PS my little old B7200 will lift 800 Lbs with the pressures cranked up some.
   / Is it just me, or does this go too far? #68
Lift up to 1277lbs†
Someone on another thread mentioned the 59" was an SAE in the Sae Carry Position (59" above ground line)
Just for giggles I use a 61" bucket on my 2520 - what's the most volume the 61" can hold and best guess on how much it would weigh - I know I wont fit 1,000 lbs of free weight in the bucket, so any material that comes to mind that may come close? all I know is I stuff it all the time and it goes up...willing to try and document it, maybe this weekend
Duc
If you really want to test this, the only way to do it is with a load cell. Even throwing weights in your bucket is pointless. Yea you know what they weigh - but we go back to this same issue.. where exactly where in the bucket are they. Set them at the front edge and your capacity drops quite a bit - curl the bucket back and your now lifting more.
I personally do own a load cell and have tested tractors with it. If you would like to rent it (it cost me $350) for a few days I'd certianly let you.
   / Is it just me, or does this go too far? #70
Neil, could you describe how the load cell works? Sounds interesting.
   / Is it just me, or does this go too far? #71
If you have ever seen 100 lb plates then you will know it will sit at the edge as well as the back of the bucket. Im pretty certain it will give a real good indicator of whats the abilities are. And I will save myself $350 LOL..
I will get around to doing this one day
Its pretty simple. Its an S-shaped piece of steel with a sensor on it that measures the amount of deflection in the metal when its pulled upon. The S has a big eye bolt though either end. Using this you can attach to a single point and pull. I've actually tested a handful of tractors with it and I was amazed how each one preformed exactly to its given ratting, no more, no less. What is interesting is that you can easily see a real world example of how the lifting point radicly changes the results.
   / Is it just me, or does this go too far? #73
OK, Neil I am not saying that this isn't so. But that does SEEM strange. I mean, even though you are using a load cell, I amagine there are other variales (atmospheric pressure, sunspots, alignment of Jupiter and Saturn...) that affect the measurements. It seems like the 'official' tests always leave just about everything falling short of their advertised numbers... But two machines side by side - it will certainly give a fair representation.
But that said, your point about easily seeing the effect of the different load points is surely a big eye opener...
   / Is it just me, or does this go too far? #74
Mike those 'official' test are probably the Nebraska tests. Realize they far more rigid & scientific than parking lot tests, also realize they are only performed on AG tractors and not on our CUTs. I suspect that while the tests attempt to be neutral, they were designed many years ago and now are still a great source of information and comparison and a way to keep the manufacturers honest, but they are not a reliable indicator of the performance or capacity of a CUT of any brand.
And Neil and I spent quite a bit of time about a year ago trading information on this issue, my unoffical data and his load cell measurements always seemed to confirm each other. I often harp (ad nausium) on the issues of measurement points for loaders and 3pt lifts, but it is something that many users are simply uneducated about. It actually is scary that so many dealers are also ignorant of the differences in how the different points make HUGE differences in capacity.
   / Is it just me, or does this go too far? #75
OH, and in no way am I suggesting that HE or anyonyne heare is intentionally or unintentionally attempting to mislead.
Neil, you mentioned you might rent it out... is it easily shipped like by UPS? Maybe we can get a 'Road Test' going - even setup a Road Test forum for similar things...
   / Is it just me, or does this go too far? #76
A couple of comments about loader ratings that this thread does not seem to address:
1. It is my understanding that dedicated wheel-loaders and skid-steer loaders are typically rated by their tipping capacity. And this number has a 2x or 3x (I forget) safety factor baked into it. So if the machine would literally tip over with 6000 lbs in the bucket at any point in the lift, the rated "tipping" capacity would be only 2000 or 3000 lbs. Tipping capacity is a good way to get an idea og how much the machine can safely lift when properly ballasted. I think perhaps when tipping capacity gets used interchangeably with hydraulic force curve capacity it can lead to quite a bit of confusion.
2. On many of these CUTs and sub-CUTs, the rated loader lift capacity actually far exceeds the rated front axle (and mayeb tires too) capacity of the machine the loader is mounted on. For example, my JD 4100 with 410 loader. I think the loader can hydraulically lift like 1200 lbs to 24" or something. But the front axle of the tractor is only rated for something like 1100 lbs. The front axle is already carrying maybe a third of the weight of the tractor (600 lbs) and substantially the entire dead weight of the loader and bucket (maybe another 500 lbs?). I think the math comes out that there is technically zero remaining front axel capacity for any live payload in the loader bucket.
So putting a loader on a CUT or sub-CUT, and expecting to safely lift much over 1000 lbs to 1500lb is asking a lot from a machine that might only weigh 2000 to 3000 lbs itself.
   / Is it just me, or does this go too far? #77
keeney; ?I thought the load capacity that is advertised is taking in consideration the weight of the loader, and the capability of the axles?
?Otherwise wouldn't even adding a load of mulch would be very risky? I had a 4100 and would routinely lift 300 - 500 pounds of materials, rocks, etc (occasionally lift 500 - 600), and when I went in for the routine check-ups, never heard a peep from the Dealer worrying about load capacity - as long as I kept below the rated (Verbal from dealer) lift capacity of the loader (200CX).
   / Is it just me, or does this go too far? #78
The axle capacity I was referencing is the gross axle weight rating. It doesn't care what is on the axle - just how much it weighs. "Gross" includes the tractor, the oil, coolant, the fuel, the operator, the loader, the bucket, and what is in the bucket. Like I said, on my 4100, the axle rating technically left zero capacity for any payload in the bucket.
Also, tire ratings are going to be gross (per tire) at max pressure. These numbers are stamped on the tire. A CUT or sub-CUT 4-ply front tire might only be rated for 650 or 750 lbs, each.
- Rick
   / Is it just me, or does this go too far? #79
that's a big part of the reason for so much rear ballast, to leverage the weight over the entire machine instead of it being just on the front axles. as we all know, the machine will lift far beyond the ratings, just use common sense.
   / Is it just me, or does this go too far? #80
Ballast is needed for safety to prevent tipping and to keep the front axle from having to provide all the power to move the machine (front axles are made to assist with moving the machine, not to do all the work, they are much lighter than rear axles), however that does not lighten the payload on the front axle unless I am missing something.
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
2020 Deere 50G (A53317)
2020 Deere 50G...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
iDrive TDS-2010H...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
