Dump body winch
/ Dump body winch #1
kubota00
I made this to pull the splitter on but it work well for many things. Power in power out and will free spool out, 1500 lbs capacity. Self contained not wired into the truck one bolt holds it in place.
/ Dump body winch #3
I'd have put it on the side with a pully or roller hause were you have the winch, that way you could shift it while standing on the ground. it could also be permanently mounted because it wouldn't be in danger of being crushed. leaving the hook achored to the side by the winch when it isn't in use would let you run out the cable without hopping in back too.
I can see why you wouldn't want power cables flexing with each cycle of the dump bed, but you could use the plug system for removable winches that Warn has. that also goof for jumper cables too.
/ Dump body winch #4
Nice concept. I like the way you did the ramps with bolts going in the crack between the gate and bed, if I see it correctly. Do you have any concern with acid spilling out of the battery when the bed it tilted?
/ Dump body winch
Groo
There were a number of ways I considered mounting it but it just came down to what was the quickest and I wanted to use materials I had on hand. Here a close-up of the package and if you notice the bar on the bulkhead of the body that痴 all that is left on the truck when I take it out. When I haul gravel I just cover the unit with a trap.
/ Dump body winch #6
I like it.
Would like to see washers and lock nuts for the bar though.
/ Dump body winch
BobRip
Here a close-up of the ramp end. It is a piece of angle that I shimmed to get the right angle so it slips between the gate and the body. Seem to work well. I think the battery is sealed well enough doesn稚 seem to be a problem.
/ Dump body winch #8
BobRip
Good concept and design on the angle iron. Just thought I would mention the battery leakage in case it was a problem. I did not want you to get acid on the dumper.
/ Dump body winch #9
Great idea i could see my using something like that.
I would like see more pics of the truck i looks pretty new.
Shane
/ Dump body winch
rtdiggr
The truck is a 08 Chevy 3500; I got in February in from a dealer in CT. It was tough to find a work truck with the LT package with a Dmax. I need to find a toolbox that will fit into the cab protector for the chain saws, the side boxes are too short for the 20覇rs. More pics
/ Dump body winch #11
That is one nice truck. I like that the sides fold down. I could see that being really useful.
Shane
/ Dump body winch #12
rtdiggr
Nice truck
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
New/Unused SDLL580 Mini Track Loader (A65583)
New/Unused SDLL580...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2019 East...
2012 Peterbilt 337 S/A 16ft. Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
Metal Sasquatch Holding Beverage (A65583)
Metal Sasquatch...
