when to use high and/or low gear with JD 2305
   / when to use high and/or low gear with JD 2305 #11
I always use Low when using the FEL.
For going about the property, I use High range but gear down to Low when on a steep upslope. It sometimes will not drive in High when starting off in it on a steep slope. I pretty much have to keep the rpm on the engine above 1500 to keep from straining the engine when going upslope in High.
Low range gives a lot more retardation than High when going downhill. ALWAYS park with it in Low. Don't think High will keep it from rolling. My 4010 is about the same weight as your 2305. Always park with the brake on, too.
Ralph
   / when to use high and/or low gear with JD 2305 #12
*For going about the property, I use High range upslope in High.
Ralph
That's me .
Everything else is low range.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59575)
1999 TRANSCRAFT...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
