FEL level indicator
/ FEL level indicator #1
ACHINBAC
Middleborough, Ma
BX24
Wanted a lever indicator for the bucket, but not a bolt on rod type. After a bit of head scratching, a couple coors lights, and digging through some old parts boxes, this is what I've come up with:
The sensor in the arm is a magnetic reed switch. The magnet is bolted to a carved up stainless washer. Both will be painted orange when I get a chance. The set up is very accurate and adjustable via the magnet/washer clamp, and is not affected by snow or dirt. The magnet is neodymium and scary powerful. The switch operates a high power red LED mounted on the plastic shroud at the base of the FEL stick (TBD- mocked up in the picture) and can be seen out of the corner of your eye even when not looking directly at it. Switch wire was routed inside the FEL arm, out, and then bundled with the hydraulic hoses. LED goes red the second the bucket is level - you can set level with the arms on the way down, or without hanging off the side of the tractor or in the dark during a complete white out in a blizzard with your eyes almost frozen shut.
/ FEL level indicator #3
Unfortunately, it will only give bucket level at one arm height. Raise the arms and the bucket will read level, but will be tipped back significantly.
jb
/ FEL level indicator #4
I've been wanting/thinking about such a feature. As shown here, I do have to agree with John's comments. Unless I'm not seeing something, this looks more like a position indicator. i.e. the bucket is level in only one situation.
What I want but haven't got around to doing the design on is to have an indicator that truly tells when the bucket is level regardless of bucket height and another mode of operation for when you desire the bucket to be parallel to the ground. The second mode of operation is desirable when you want to scoop stuff off the ground and the grade not being level.
I have something similar on the rear of my tractor which is part of the UFO controls on some Yanmar's. With the flip of a switch my 3pt is kept level in real time within the range of +/- 10ー left/right. This is a fairly complex system but only handles side/side situation and with a bucket, grade is important in some situations.
ACHINBAC, please don't take it as we're dumping on your effort but this does not appear to truly indicate "level" in all situations. Does look like a nice clean install on the bucket and if it does what you need/want, good for ya.
/ FEL level indicator #5
Cool devise from an engineering standpoint. All of my tractors have bucket level rods on them. I neer use them, finding that my eyes can still tell a level bucket just fine.
Andy
/ FEL level indicator #6
Andy
I never used mine either so I took it off...The top of my bucket is on the same plane as the bottom, so it's easy to see the position of the bucket from the seat.
John you are correct. I worded the post title incorrectly. It is technically a wheel plane indicator for the bucket bottom, and of course is calibrated to indicate only that when the bucket is down for snow removal (we have a gravel drive). It is possible to indicate "level" with a different system but that would be beyond my needs and is a more involved project. Mercury switches and pendulums bounce around and would give erratic result, though would give an indication if the tractor was motionless. A linkage anchored at the FEL arm mount articulating the magnet would allow the bucket to be raised and the "wheel plane" could be determined at any height. Not true level of course. 2 more green LEDs on either side of the red existing and 2 more reed switches would also indicate if you were off - tilted up, or down.
This was a fun, simple (and cheap) project that anyone can do. Veteran operators would find it useless I suppose, but last year during a couple of bad storms at night I wacked the driveway and the lawn in a bunch of spots pretty good. Will no doubt do it again this year too, but maybe less times.
Dave
/ FEL level indicator #8
Dave,
Your project was nicely done and can be helpful - especially for newer users with less feel for position. And you are right, getting "real" bucket level is a harder thing. Very useful for folks that use forks. I always thought that a couple variable resistors that mark the full swing extent of the bucket travel and boom arm lift travel could be combined to calculate bucket level. I have the idea of how that would work, but not the skills to pull it off. (or the burning desire, spare time, spare change for parts, etc)
jb
/ FEL level indicator #9
This simple little switch might work good for keeping it true horizontal without too much switch bounce:
Tilt Activated Switch
Of course, it would have to be modified to be more rugged. But, that wouldn't be hard to do. Contact spacing would dictate sensitivity and accuracy.
/ FEL level indicator #10
Howze about a ball bearing inside a plastic tube filled with oil of an "appropriate" viscosity ?
Sure it would be slower to react when colder, but maybe a thin enough oil and a ball bearing with enough but not too much clearance in the tube would have the right dampening.
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2018 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
MASSEY FERGUSON 4710 TRACTOR (A59823)
MASSEY FERGUSON...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
