Any news on 86hp Mahindra?
   / Any news on 86hp Mahindra? #1
Slippy
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Anyone got any news on the 86hp tractor Mahindra has out? It is not on their web site, but I hear it is out without the cab. Any word on when it will be out?
   / Any news on 86hp Mahindra? #2
I assume you are refering to the 8560. It's actually an 83 hp machine. Looked the ROPS version over at the dealer last week. It's a massive looking tractor. Looks just like the 7520 except bigger. The dealer said it would be available in the cab configuration late spring. Then only on a limited basis. Supposed to be at the NFMS in Louisville Ky in Feb, but I aint holding my breath.
I actually found a dealer that has an 8650 but no cab. Mahindra's web site has reference to it in the financing but not in the models offered section.
   / Any news on 86hp Mahindra? #4
I do not actually know, but I think that it looks like a 7520 with an inner cooler and a vent to accommodate that cooler. Although I imagine that there may be other minor differences also. Sure would be nice to see one with the cab.
   / Any news on 86hp Mahindra? #5
Here's a link
NEW MAHINDRA 8560 4-WHEEL DRIVE TRACTOR
The loader lift is 4100 lbs to full height with a breakout force of 5830 lbs. 83 hp with 70 at the pto. 12F 12R synchro shuttle. 17 gpm hydraulics. 5500 lb lift capacity at the 3 pt.. The Rops weighs in at 7297 lbs.. Wears 11.2x24 front and 16.9x30 rears. 13.1 ft turning radius.
Mt. View is right it's a wet sleeved, 17.2:1 compression, 203.2 ci, 4 cylinder that's turbocharged and intercooled. Also is a direct injection engine.
I picked up the brochure on it since I've anxiously awaited this beast for a couple years now.
After looking it over and hearing the price I'm not sure I would have waited. The 7010 can do almost anything this tractor could do. For me the size of the 7010 is a plus. Like I said this new one is a massive tractor.
What type of shift/transmission does the 7010 have? Does the cab have air and heat?
   / Any news on 86hp Mahindra? #7
Sorry, TYM?
   / Any news on 86hp Mahindra? #9
TYM manufactures the 7010 for Mahindra, as well as the T7074 for Montana. The Mahindra version uses a Mahindra engine, the Montana and TYM (T700) versions use Deere engines. The TYM T903 looks like a great deal, 90 engine HP (CAT 4cyl. diesel), 4wd, cab tractor, 32x32 powershift power shuttle trans. I saw an ad for one on TractorHouse at $42,300. The official TYM Tractors Web site
   / Any news on 86hp Mahindra? #10
Nice tractor! That would fit my hay operation nicely. :)
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2017 Ford Transit 250 Cargo Van with Lift (A56858)
2017 Ford Transit...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
Rooster Weathervane (A55853)
Rooster...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
