Hydraulic Chute Rotation ?
/ Hydraulic Chute Rotation ? #1
DCJL
Northern Vermont
New Holland TC34DA
I've read a bunch of these threads but have not found what I was looking for so....
Is there a reason you cannot cut the hand crank rod shorter and mount a hydraulic motor to it to turn the worm gear that is already attached to the chute?
/ Hydraulic Chute Rotation ? #3
Exactly what I did to my new Blizzard...It was cheape & better to do my own then the factory hydraulic cylinder setup...which I wasnt a fan of...
That looks SWEEEETTTT......
A couple of questions if you could be so kind....
Exactly what hydraulic motor did you use?
Where did you get it from?
What was the cost?
Did you need to put in any reducer to get it to rotate slower?
thanks,
Don
/ Hydraulic Chute Rotation ? #5
Thank You Very Much!
Its an Eaton/Char-Lynn J-Series Geroler Motor
What was the cost?
In my Hometown we have a guy with who's business it is to hit industrial auctions all over the Northeast buying all kinds of stuff...everything from nuts & bolts to Lathes, Milling Machines, Tooling, etc.. His business is really just buying & reselling industrial & commercial items. This summer he was at a Food Packaging auction and ended up with TONS of these & other hydraulic motors off conveyors etc... I picked 2 of them up for $40.00
Yep, I got a needle valve so I can adjust the speed precisely. I tweaked it this weekend and "locked it down" where I wanted it.
/ Hydraulic Chute Rotation ? #6
Neat! I ordered up the kit from my blower's manufacturer and it works well. Would have been more fun to rig something up myself. I think the motor is a great idea!
Thank you very much for that info. Great help. Now I have to go find that motor! thanks.
/ Hydraulic Chute Rotation ? #8
I like your mount setup a lot...very clean! Dyer, retired
/ Hydraulic Chute Rotation ? #9
Any motor should do you fine...in an application such as this, I'd seriously shop more on price then on "specs"...figure if a person can turn the setup by hand, ANY "Low Speed/High Torque" motor should do you fine...mine is rated at 4 HP
If I were to have had bought a new motor, I would have gotten something similar to this:
Burden Sales Surplus Center Item Detail
OK, thanks. I'm a newb when it comes to hydraulics, but learning fast. I'll see if I can pick up a cheap motor somewhere.
/ Hydraulic Chute Rotation ? #11
Maybe a dumb question, but...Are "motors" and "pumps" the same thing basically? In other words, could I buy something called a pump, and use it as a motor?
/ Hydraulic Chute Rotation ? #12
Some are some not. Northern tools has many and in there description will say whether it can be used as a pump, motor or both.
