trailer hitch receiver tubing
   / trailer hitch receiver tubing #11
If you lived around here, you could just come by the house and pick up a piece of the 2x2 that you need. I have a bunch of pieces of it, 42" long. Saw the need for it, and grabbed it while the getting was good.
David from jax
   / trailer hitch receiver tubing #13
These guys are not getting it, Go to your local steel yard and get a piece of 2"x2" x 1/4" wall square tube and drill a 5/8" hole in and your done.
I tried that true temper. The weld inside the 2x2 pipe made the inside diameter to small for my store bought hitch to fit into. I ended up having to buy a receiver pipe. I did check the fit before I cut up the 2x2 pipe so I'll still get good use out of it. :)
   / trailer hitch receiver tubing #14
harbor freight sells the reciever in 12 and 18 inch lenghths
   / trailer hitch receiver tubing #15
Better eyeball that HF receiver closely...several I looked at in the store had the dreaded inside welded seam flash, the ball mounts right next to them on the shelf woudn't even slide all the way in:cool:
   / trailer hitch receiver tubing #16
2 1/2" heavy wall for receiver and 2" heavy wall for hitch. Both will have rounded outside corners if you get heavy wall.
   / trailer hitch receiver tubing #17
See post number 4 in this thread- regular 2.5x2.5 with a .25 wall is not the correct stuff. Needs to have a slightly thinner wall to work well....
I am in Trumbull County ( Lordstown/ Newton Falls)
I want to make a boom pole and a long ball hitch to slide into the receiver I welded on my bucket. One piece about 4 foot and the other about 2 feet.
   / trailer hitch receiver tubing #20
Was hopin you were closer. I can give ya a 2ft. piece,, but how to get it to ya is another issue. It would probably be easier for you to go to your local steel/metal supply . Just tell em what your looking for, and they'll take care of ya. Unless you travel up this way , then let me know, and I'll cut a piece for you!!
1449 (A57192)
1449 (A57192)
Sellick 560 Forklift (A57148)
Sellick 560...
2016 John Deere 5055E 55HP Utility Tractor (A55973)
2016 John Deere...
GMC 2500HD 4wd Service Truck (A56435)
GMC 2500HD 4wd...
2002 International 9200i Truck (A56435)
2002 International...
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A56858)
2015 Ford F-550...
