Rear Blade very, very strong rear blade
   / very, very strong rear blade #1
hotchkiss
Gold Member
Ohio
JD 6330, JD 5055e, Ford 4000,
I want to purchase a new or used rear blade the is 8 - 10 feet wide and I want one that I cant tear up with a 90hp tractor. Any recommendations.
   / very, very strong rear blade #2
Landpride,Befco and Woods !!!
   / very, very strong rear blade #3
Here it is. A word of caution. You might not tear it up, but it's gonna wreak havoc on your wallet!
Rhino tough!
2500
   / very, very strong rear blade #4
Avoid King Kutter.
   / very, very strong rear blade #5
Avoid King Kutter.
I have a 7ft.Heavy duty(yellow)king kutter that I have used for about 3 years now with no issues.I had bought the low end KK 7ft. model (blue)that only lasted about 1-2 years.coobie
   / very, very strong rear blade #6
But obviously the heavy duty ones for your tractor size. All of these manufactures make atachments for small tractors too.
I know in Landpride's case attachments come in "series" that are 4 digits long, 10xx, 15xx are light duty Cat 1, 25xx and 35xx .. respectively are getting heavier duty.
Andy
   / very, very strong rear blade #7
I just went to Landpride's site and I see they have changed there use of numbers. The numbers are still used but there position has been reversed, for instance a 1558 (15 series, 58 inch wide tiller ) is now a 2 letter code 15 tiller. Under rear blades they have several that would suit your needs.
Andy
   / very, very strong rear blade #8
Landpride would be my suggestion.
Check your local dealers for used ones. I often see them that size laying in back round these parts.
   / very, very strong rear blade #9
If you get a Land Pride, you will need either a RBT40 series for 65-100hp and that is available in 84", 96" and 108" widths. Or an RBT45 series for 70-125hp, in 96" & 108" widths. Their big blade is the RBT55120, 120" wide.
Land Pride also has these blades rated for gross weight with the 40 series rated for 9500lbs and the 45 & 55 series rated at 15,000lb.
Another very good rear blade is Bison. I actually wanted one of those, but the wait was what I thought was to long so I went with a Land Pride RBT45108. They are not cheap, but I'm not going to bend this one up either.:D
   / very, very strong rear blade #10
I checked out the price on those Rhino's -- all I can say is "ouch".
And people think that $2000 for a box blade is expensive! But, if you spend the money, it is only spent once and done, cuz that sucker is meant to last a lifetime.
jb
Gator (A50324)
Gator (A50324)
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
