Rear Blade very, very strong rear blade
   / very, very strong rear blade #1
hotchkiss
Gold Member
Ohio
JD 6330, JD 5055e, Ford 4000,
I want to purchase a new or used rear blade the is 8 - 10 feet wide and I want one that I cant tear up with a 90hp tractor. Any recommendations.
   / very, very strong rear blade #2
Landpride,Befco and Woods !!!
   / very, very strong rear blade #3
Here it is. A word of caution. You might not tear it up, but it's gonna wreak havoc on your wallet!
Rhino tough!
2500
   / very, very strong rear blade #4
Avoid King Kutter.
   / very, very strong rear blade #5
Avoid King Kutter.
I have a 7ft.Heavy duty(yellow)king kutter that I have used for about 3 years now with no issues.I had bought the low end KK 7ft. model (blue)that only lasted about 1-2 years.coobie
   / very, very strong rear blade #6
But obviously the heavy duty ones for your tractor size. All of these manufactures make atachments for small tractors too.
I know in Landpride's case attachments come in "series" that are 4 digits long, 10xx, 15xx are light duty Cat 1, 25xx and 35xx .. respectively are getting heavier duty.
Andy
   / very, very strong rear blade #7
I just went to Landpride's site and I see they have changed there use of numbers. The numbers are still used but there position has been reversed, for instance a 1558 (15 series, 58 inch wide tiller ) is now a 2 letter code 15 tiller. Under rear blades they have several that would suit your needs.
Andy
   / very, very strong rear blade #8
Landpride would be my suggestion.
Check your local dealers for used ones. I often see them that size laying in back round these parts.
   / very, very strong rear blade #9
If you get a Land Pride, you will need either a RBT40 series for 65-100hp and that is available in 84", 96" and 108" widths. Or an RBT45 series for 70-125hp, in 96" & 108" widths. Their big blade is the RBT55120, 120" wide.
Land Pride also has these blades rated for gross weight with the 40 series rated for 9500lbs and the 45 & 55 series rated at 15,000lb.
Another very good rear blade is Bison. I actually wanted one of those, but the wait was what I thought was to long so I went with a Land Pride RBT45108. They are not cheap, but I'm not going to bend this one up either.:D
   / very, very strong rear blade #10
I checked out the price on those Rhino's -- all I can say is "ouch".
And people think that $2000 for a box blade is expensive! But, if you spend the money, it is only spent once and done, cuz that sucker is meant to last a lifetime.
jb
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
