Ballast new wheel weights and and hook on the bucket
   / new wheel weights and and hook on the bucket #1
Johnny_B
Western PA
MF GC2410 TLB w/ 60" MMM
Here are some pictures of the new homemade wheel weights and the hook I welded on the bucket of the GC2410.
I'll post a few more pictures of the wheel weights in the customization forum.
   / new wheel weights and and hook on the bucket #2
Good Mornin Johnny,
Nice job on the weights, any idea how much they weigh?
   / new wheel weights and and hook on the bucket #3
Even with the backhoe on you need wheel weights?
DEWFPO
   / new wheel weights and and hook on the bucket #4
Especially with the backhoe on. My front tires hop all the time when I go up my hill.
   / new wheel weights and and hook on the bucket #5
I must have misread the photo. It appeared the wheel weights were on the rear. DEWFPO
   / new wheel weights and and hook on the bucket #6
So Johny, how did you make those? That is one big chunk of steel. Why did you opt for wheel weights rather than filling your tires?
   / new wheel weights and and hook on the bucket #7
So Johny, how did you make those? That is one big chunk of steel. Why did you opt for wheel weights rather than filling your tires? I think I would like to have somthing like that.
   / new wheel weights and and hook on the bucket #8
The hooks are great, i have 1 on each side, and 1 in the middle. Soo usefull
-Chris
   / new wheel weights and and hook on the bucket #9
How are the rear wheel weights going to help keep the front tires on the ground? Their hopping because of all the weight behind the back axle.
You need more weight on the FRONT of the tractor, (preferred). Or, less weight on the back end.
If you have a weight bar on the front, (below the brush guard), hang your weights on there.
With the BH on, the fronts always going to bounce some. This happens even on big, full size TLB's
Good Mornin Johnny,
Right around 74 pounds (based on my calculations):
diameter (inch) = 8.5, length (inch) = 4.6, area (sq in) = 56.745, volume (cu in) = 261.027, density of low grade steel (lb/cu in) = 0.283 -------> mass (lb) = 73.870.
DEWFPO
I really don't need them with the backhoe on, but they'll add a little bit of extra weight when I'm running a landscape rake or tilling discs.
My Father (God rest his soul...passed away this past January) had all kinds of "stuff" around his garage, so I got the bolts and solid steel cylinders for free. I was actually planning on filling the tires with washer fluid, but for the price of a few cans of primer and paint and a handful of welding rods, the price was right for the steel weights.
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2019 KEESTRACK K6 SCALPING SCREENER (A51242)
2019 KEESTRACK K6...
196046 (A50459)
196046 (A50459)
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
