Snow snow blade skid shoe Adjustment and have questions
   / snow blade skid shoe Adjustment and have questions #1
stuarth
Gold Member
Northern Ohio
Kubota BX2670
I attached a picture of my skid shoes and the way they are adjusted today. The washers can go either on top or bottom of the support causing the shoe to be raised or lowered plus the washers can go the way they are opposed or lay flat together which would allow some up or down movement if object is struck. I just want to know what is the correct way or the manual way to do this.
Thank you
   / snow blade skid shoe Adjustment and have questions #2
http://www.tractorbynet.com/forums/attachments/kubota-owning-operating/114258d1226695277-snow-blade-
Thank you
Pair all 8 washers like the 2 on top in your picture
Next place one pair on the bottom
Now put the other 3 pairs on the top.
Thanks for the info again.
   / snow blade skid shoe Adjustment and have questions #5
Just curious, what is the model of the blade in the picture?
   / snow blade skid shoe Adjustment and have questions #6
if anyone needs a set of these, drop me a line. We have 7 skid shoes kits the in the warehouse. I'll sell them at cost plus freight.
The picture is a BX2763a blade that I just bought, putting on a BX25
   / snow blade skid shoe Adjustment and have questions #8
http://www.tractorbynet.com/forums/a...277-snow-blade-
It will work on any of the BX tractors.
It is 60'' wide.
It's hydraulic lift and hydraulic angle.
I have this blade on this tractor.
__~ There is
another blade available also .
~ It will work on any of the BX tractors too.
~ It is 54'' wide.
~ It's hydraulic lift and Manual angle.
These 2 blades are the only blade options for the BX Tractors.
   / snow blade skid shoe Adjustment and have questions #9
I think that this is the blade that I have on order for my B2320. It looks like it is pretty heavy duty. Should be plenty heavy for snow plowing which is all I plan on doing with it.
   / snow blade skid shoe Adjustment and have questions #10
I pushed 4'' of snow with it last winter .
It was like going through butter with a hot knife.
This summer I used it on 3 small yard projects smoothing out ruts and backfilling 2 ditches.
The thing I like about the blade on the bx1500 over the fel on the bx23 is it's easier to tell where the cutting edge is when you are grading leveling and back draging.
550 GAL STAINLESS STEEL VAT (A51244)
550 GAL STAINLESS...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2002 INTERNATIONAL 4700 4X2 SEWAGE TANK TRUCK (A51243)
2002 INTERNATIONAL...
2015 CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
12 ft Chisel Plow with Rolling Baskets (A52128)
12 ft Chisel Plow...
VOLVO L45G RUBBER TIRE LOADER (A51242)
VOLVO L45G RUBBER...
