1943 2N Cooling Fan Rotation
   / 1943 2N Cooling Fan Rotation #1
thl
Member
Bridgeport Michigan
Kubota B2150
Should the cooling fan on my 2N be circulating the air flow out the front of the radiator and tractor or pulling the air in through the radiator towards the engine as a regular car fan would do? Mine is pushing the air out the front of the tractor. Comments?
   / 1943 2N Cooling Fan Rotation #2
It should pull air through the radiator.
   / 1943 2N Cooling Fan Rotation #3
Toad.. would you believe 'pusher fans' were a common item that could be added to a ford tractor???
can get 4 and 6 blade fans....
9n 8600d is a 6 blade pull fan
8n 8600a is a 4 blader
to the original poster... sound slike you got pusher fan.. good for you.. keep it and use it.. or replace with a regular fan and sell it on ebay.
soundguy
Soundguy,
I was hoping that you'd weigh in. I must have the 8n 8600a. I will keep it. Thanks for the advice.
Terry
   / 1943 2N Cooling Fan Rotation #5
I sure would...
soundguy
   / 1943 2N Cooling Fan Rotation #6
pusher fans rotate the same direction as the regular ones, but the vanes are set the other way. Some think that they prevent chaff from loading up on the radiator fins if you're working where there's a lot of seeds etc. six of one, half dozen of the other
simonmeridew
   / 1943 2N Cooling Fan Rotation #7
SOUNDGUY , i beleive you as i know you are very expert on these tractors, but my question is why would they want to push air from the engine?
   / 1943 2N Cooling Fan Rotation #8
Figure you are the poor guy out riding on the tractor in 105' weather and no shade out plowing all day .. so.. you want that hot air that's cooling the engine on you.. or maybee you want it out the front?
fast forward to winter.. and that hot air off the engine / radiator might feel real good.. that and a heat hauser.. etc..
soundguy
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2013 FREIGHTLINER CASCADIA (A50854)
2013 FREIGHTLINER...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
Diesel Fuel Tank with Pump (A50860)
Diesel Fuel Tank...
