Car maintenance-fluid flushing
/ Car maintenance-fluid flushing #1
randy41
Linden VA
My wife's 07 civic (bought new in 11/06)went in for 45k service today. The service guy said it needed the power steering fluid flushed and the same for the brake fluid. He wanted $150 for both. I said no. I didn't sound friendly about it over the phone. O well.
Do you guys think this necessary maintenance? Is 2 years/45k too soon to be needed? Is the price right?
/ Car maintenance-fluid flushing #2
The price could be right - depends what are your options. If you have to buy tools and than attempt to hack it somehow, $150 is proly cheaper. If you are OK shade tree mechanic with enough tools, I believe you could do it yourself for fraction of the cost.
The fluid typically needs changing when it absorbed too much water, does your wife experience any problems with any of those systems?
To replace fluid in the brake system I use big syringe and a piece of hose to suck the fluid out from the wheel end one wheel at a time. Works like a charm, takes and hour max.
Power steering fluid, it depends on the vehicle where to disconnect the circuit.
/ Car maintenance-fluid flushing #3
I don't think a 2007 Honda needs any fluids flushed, this is just a money maker for the dealer. Look in your owner's manual for required maintenance and stick to that.
/ Car maintenance-fluid flushing #4
I know ppl that do change the PS and brake fluid, but they typically are runnign their cars on the track (street car in performance driving schools) and their brake fluid is usuall been subject to a lot of high heat..
I think you can purchase a test kit (sorta like a litmus test) to test these fluids..
IF they do need to be changed I bet you can find another local (non dealer) shop that would do it for you..
The brake fluid can easily be exchanged - you would either need someone to pump and hold the brakes OR buy a pump...Just dont forget to keep adding brake fluid..
good luck
Brian
/ Car maintenance-fluid flushing #5
Car dealers are getting creative again to bring customers in the door... nitrigen filling of tires in a big seller here now (29.95).
mark
I love this support group.
There have been no problems with any of these systems on the car. My wife drives it. I would know immediately if there was a problem.
/ Car maintenance-fluid flushing #7
Wallet vacuum.
/ Car maintenance-fluid flushing #8
I do change out my brake fluid about every year or 2. You will get moisture in the brake system. How long will it take ?? Don't know. But I have seen a corroded brake system from the failure to change out brake fluid / flush the system
/ Car maintenance-fluid flushing #9
I have had several brake line failures over the last several decades.
I can say with great confidence that they have ALL been from EXTERNAL corrosion.
It is true that brake fluid is hygroscopic, i.e. it absorbs moisture from the air, however steel brake parts will rust internally only at an incredibly slow rate, since the only available oxygen is that which is dissolved in the brake fluid - and I doubt that it is "available" to steel that is coated with brake fluid (a particular hydraulic oil).
The scams rely on mention of the dissolved water, but make no mention of the almost complete lack of available oxygen, for which "rusting" is essential.
I have about a 25ft section that I replaced on a trailer this year, it is in the trash but I will try to retrieve it and if practical slice it open, take pictures of the (lack of) internal corrosion and post them. Not until next week, at the earliest.
/ Car maintenance-fluid flushing #10
Look at the color of the fluid. If its dirty looking than it would be advised. Also follow the manufacture recommendations as in the manual.
That being said, a O& Honda shouldn't need a darn thing flushed.
Steve, who works in the auto repair business.
/ Car maintenance-fluid flushing #11
This kind of reminds me of the time I took my Dodge pickup into the dealership to have the transmission tested. They told me the test was $75. When I went to pick it up, they wanted to charge me $150 for the job because they added a "fluids disposal fee." Let me see now. . . there was no fluid added on the bill, but yet they told me it was a "standard" fee.:rolleyes:
/ Car maintenance-fluid flushing #12
I think I would have told them - "Give me the fluid, I'll dispose of it". This is a scam to pad out the profit on the repair.
/ Car maintenance-fluid flushing #13
Some dealers also started adding on charges for an 'environmental fees' for their shop towels wash/clean, ect....
Brian
/ Car maintenance-fluid flushing #14
Well, our 2001 Ford Windstar has had the brake system flushed.:eek: In fact, I allowed a Ford dealer to do their "recommended" 60k mile service, which included the following and cost me $1,123.68:
Change oil & filter
Flush transmission
Fuel filter
Air Induction Service
Fuel Injector Service
Air Filter
Flush Cooling System
Cabin Air Filter
Power Steering Flush
Brake Flush
Tune-up; plugs and wires​
I use a different dealer now.:rolleyes:
/ Car maintenance-fluid flushing #15
Like I said, I don't know how long it would take to cause problems. But, I have replaced brake calipers that had internal corrosion problems. You could see the pttied cylinder & the piston would be pitted. I'am sure if you lived in an area that salted the roads in the winter or lived near a coastal area you would have external corrosion problems
/ Car maintenance-fluid flushing #16
I've replace corroded brake parts before because of the fluid absorbing water over time, but never on a one year old car. This can also cause a problem in mountain driving, as the brake fluid turns to steam if the brakes overheat.
I can see a brake flush every 4 or 5 years, maybe, depending on usage and location.
Agline ADM110 Hay Mower (A64047)
Agline ADM110 Hay...
2014 Freightliner Bucket Truck (A63118)
2014 Freightliner...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
