LK3054 info needed
/ LK3054 info needed #1
PumpkinCrusher
Sagamore Hills, Ohio
Kioti LK3054
My buddy owns a mid 90's 3 cylinder diesel LK3054 with front loader. I borrowed it from him and told him I would PM it for him for letting me borrow it. Can some one tell me the oil capacity, hydraulic capacity, hydraulic filter number? This poor tractor hasn't been maintained well and I want to make sure it's done right so I can borrow it again in the future. Thanks
/ LK3054 info needed #2
Engine oil 6.1 quarts
Trans/Hydraulic fluid 27.5 quarts
Front axle oil 2.6 quarts
oil filter pt# E6201-32443
Hyd filter T2305-38831
Fuel filter 84612-43160
Air filter 15307-11081 serial #0265-00700 and lower
Air filter outer E6300-11081 and inner E6300-11091 if serial # is higher than 1265-00001
/ LK3054 info needed #3
Do your friend a favor and get a NAPA Gold #1182 oil filter. The stock Kioti filter has no anti-drainback valve; it allows oil to drain back into the sump, emptying the filter can so your next start, after a shutdown is with an empty,or nearly empty oil filter. This is not good for ANY motor, as you get a momentary lack of oil pressure, until the filter can refills.
/ LK3054 info needed #4
Are you sure about that?
I just put a Kioti oil filter on my DK 35 (same part # as Wallace listed above).
It sure looked like it had an anti-drainback valve in there to me.
/ LK3054 info needed #5
If you go to page 7, 4th post down you'll see my post reference this problem. The other indication was upon engine start-up, the oil lamp would go out, only to come right back on, and remain on for what seemed like forever, not more than a second or two, but too long for my tastes. I've not experienced this condition since changing to the NAPA filter in March of this year :confused:
/ LK3054 info needed #6
The anti-drainback valve is just a rubber diaphram just inside the filter and the E6201-32443 Kioti filter I recently installed did have one.
/ LK3054 info needed #7
I don't know what to tell ya, except I won't use one again. If ,in fact, they do have the valve, the filters I used on my tractor were ineffective. I've got a new one sitting in the cabinet, with the rest of the spare filters, anyone can have, if they want to stop by and pick it up ;)
Thanks for the info. I ended up using a Wix oil filter. I have 6 quarts in her and it barely registers on the oil dipstick. I was disappointed how crude the markings are on it. I'm used to seeing add a quart or safe marked on them.
2022 Chevrolet Trax SUV (A61574)
2022 Chevrolet...
King Kutter II Tiller for sale.
King Kutter II...
250 GALLON FUEL TANK (A64280)
250 GALLON FUEL...
International 3 Row Bottom Plow (A64119)
International 3...
2014 John Deere 644K High Lift Articulated Wheel Loader (A61572)
2014 John Deere...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
