3-bottom plow
/ 3-bottom plow #1
DMF
Mass
Massey Ferguson 1552 Cab Model
Can my 1552 pull a 3-bottom plow? I was able to pull a 2-bottom plow with my 1433...
/ 3-bottom plow #2
I would say yes and no. It all depends on the soil and how large the plows are. If you have a 3 bottom plow try it and if it works keep using it. If is doesnt you know your answer. I have a 43hp tractor with R4's on it and have tried to pull a 3 bottom and it pulls it but I run out of traction. If you have the R1 ag ties I would think you would be able to pull a 3 botton 12in plow and maybe a 14in but no bigger. Hope this helps.
/ 3-bottom plow
I should have specified a little more: My currect tractor has 52 HP with ag tires. My old one was 33 hp with Ag tires and could pull a double bottom through the soil I have.
/ 3-bottom plow #4
If the 33 horse pulled fine thats 16hp per shoe.Add on 1 more and 16 horses you get 48 horses so your 52 horse will handel it git r done!
/ 3-bottom plow #5
Probably will work. I pull a 2 bottom with my 1533.
A lot of it is about weight as opposed to horsepower. You have to be able to get it going fast enough to flip. If you have to flip uphill, I'd be a little leary, but if its good and flat you should be OK. You can always resell the plows if they dont work out....
You gettting these used, or already have them, or buying new?
/ 3-bottom plow
Looking at a set of used ones...
/ 3-bottom plow #7
If you think you can resell and at least get your money back, then I'd say go for it. If it's someone you know, maybe you can try them out first. Good Luck!!
/ 3-bottom plow #8
Loaded or unloaded tires ?
/ 3-bottom plow
Loaded tires
/ 3-bottom plow #10
With your loaded tires and R-1s, your tractor should easily pull a three bottom plow. If it is a good plow that doesn't have a bent beam and that's set up right. I have pulled a MF model 66 14" three bottom for 5 years through 15 yr old sod, and clay with flint rocks the size if a persons head with my MF1440.
100 gal L Portable Fuel Tank (A66408)
100 gal L Portable...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
2012 Chevrolet Colorado (A64194)
2012 Chevrolet...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
Mini Universal Forks (A65640)
Mini Universal...
3Pt Hydraulic Post Driver (A66408)
3Pt Hydraulic Post...
